SnapCenter Plug-in for VMware vSphere 4.8
Disable and enable SnapCenter Plug-in for VMware vSphere
If you no longer need the SnapCenter data protection features, you must change the configuration of the SnapCenter VMware plug-in. For example, if you deployed the plug-in in a test environment, you might need to disable the SnapCenter features in that environment and enable them in a production environment.
Before you begin
  • You must have administrator privileges.
  • Make sure that no SnapCenter jobs are running.
About this task
When you disable the SnapCenter VMware plug-in, all resource groups are suspended and the plug-in is unregistered as an extension in vCenter.
When you enable the SnapCenter VMware plug-in, the plug-in is registered as an extension in vCenter, all resource groups are in production mode, and all schedules are enabled.
Steps
  1. Optional: Back up the SnapCenter VMware plug-in MySQL repository in case you want to restore it to a new virtual appliance.
  2. Log in to the SnapCenter VMware plug-in management GUI using the format https://<OVA-IP-address>:8080.
    The IP of the SnapCenter VMware plug-in is displayed when you deploy the plug-in.
  3. Click Configuration in the left navigation pane, and then unselect the Service option in the Plug-in Details section to disable the plug-in.
  4. Confirm your choice.
    • If you only used the SnapCenter VMware plug-in to perform VM consistent backups
      The plug-in is disabled, and no further action is required.
    • If you used the SnapCenter VMware plug-in to perform application-consistent backups
      The plug-in is disabled and further cleanup is required.
      1. Log in to VMware vSphere.
      2. Power down the VM.
      3. In the left navigator screen, right-click the instance of the SnapCenter VMware plug-in (the name of the .ova file that was used when the virtual appliance was deployed) and select Delete from Disk.
      4. Log in to SnapCenter and remove the vSphere host.
