Disable and enable SnapCenter Plug-in for VMware vSphere
If you no longer need the SnapCenter data protection features, you must change the configuration of the SnapCenter Plug-in for VMware vSphere. For example, if you deployed the plug-in in a test environment, you might need to disable the SnapCenter features in that environment and enable them in a production environment.
You must have administrator privileges.
Make sure that no SnapCenter jobs are running.
When you disable the SnapCenter Plug-in for VMware vSphere, all resource groups are suspended and the plug-in is unregistered as an extension in vCenter.
When you enable the SnapCenter Plug-in for VMware vSphere, the plug-in is registered as an extension in vCenter, all resource groups are in production mode, and all schedules are enabled.
Optional: Back up the SnapCenter Plug-in for VMware vSphere MySQL repository in case you want to restore it to a new virtual appliance.
Log in to the SnapCenter Plug-in for VMware vSphere management GUI using the format
https://<OVA-IP-address>:8080. Login with the admin username and password set at the time of deployment and the MFA token generated using the maintenance console.The IP address of the SnapCenter Plug-in for VMware vSphere is displayed when you deploy the plug-in.
Click Configuration in the left navigation pane, and then unselect the Service option in the Plug-in Details section to disable the plug-in.
Confirm your choice.
If you only used the SnapCenter Plug-in for VMware vSphere to perform VM consistent backups
The plug-in is disabled, and no further action is required.
If you used the SnapCenter Plug-in for VMware vSphere to perform application-consistent backups
The plug-in is disabled and further cleanup is required.
Log in to VMware vSphere.
Power down the VM.
In the left navigator screen, right-click the instance of the SnapCenter Plug-in for VMware vSphere (the name of the
.ovafile that was used when the virtual appliance was deployed) and select Delete from Disk. -
Log in to SnapCenter and remove the vSphere host.
