Modify the vCenter logon credentials
You can modify the vCenter logon credentials that are configured in SnapCenter Plug-in for VMware vSphere. These settings are used by the plug-in to access vCenter.
You must know the IP address and the log on credentials for the SnapCenter Plug-in for VMware vSphere management GUI. You must also note down the MFA token generated from the maintenance console.
The IP address was displayed when the SnapCenter VMware plug-in was deployed.
Use the log in credentials provided during the deployment of the SnapCenter VMware plug-in or as later modified.
Generate a 6-digit MFA token using the maintenance console System Configuration options.
Log in to the SnapCenter VMware plug-in management GUI.
Use the format
https://<appliance-IP-address>:8080 -
In the left navigation pane, click Configuration.
On the Configuration page, in the vCenter section, click Edit.
Enter the new password and then click Save.
Do not modify the port number.
