Modify the vCenter logon credentials
You can modify the vCenter logon credentials that are configured in SnapCenter Plug-in for VMware vSphere. These settings are used by the plug-in to access vCenter.
Before you begin
You must know the IP address and the log on credentials for the SnapCenter Plug-in for VMware vSphere management GUI.
  • The IP address was displayed when the SnapCenter VMware plug-in was deployed.
  • Use the log in credentials provided during the deployment of the SnapCenter VMware plug-in or as later modified.
Steps
  1. Log in to the SnapCenter VMware plug-in management GUI.
  2. In the left navigation pane, click Configuration.
    Error: Missing Graphic Image
  3. On the Configuration page, in the vCenter section, click Edit.
  4. Enter the new password and then click Save.
    Do not modify the port number.
