Access the maintenance console
You can manage your application, system, and network configurations using the maintenance console for SnapCenter Plug-in for VMware vSphere. You can change your administrator password, maintenance password, generate support bundles, and start remote diagnostics.
Before stopping and restarting SnapCenter Plug-in for VMware vSphere service, you should suspend all schedules.
In SnapCenter Plug-in for VMware vSphere 4.6P1, you must specify a password when you first install SnapCenter Plug-in for VMware vSphere. If you upgrade from release 4.6 or earlier to release 4.6P1 or later, the earlier default password is accepted.
You must set a password for the “diag” user while enabling remote diagnostics.
To obtain the root user permission to execute the command, use the sudo <command>.
From the VMware vSphere client, select the VM where SnapCenter Plug-in for VMware vSphere is located.
In the Summary tab of the virtual appliance click Launch Remote Console to open a maintenance console window.
Log in using the default maintenance console username
maintand password that you have set at the time of installation.
You can perform the following operations:
Option 1: Application Configuration
Display a summary of SnapCenter Plug-in for VMware vSphere
Start or stop SnapCenter Plug-in for VMware vSphere service
Change login username or password for SnapCenter Plug-in for VMware vSphere
Change MySQL password
Backup and restore MySQL, configure and list MySQL backups -
Option 2: System Configuration
Reboot virtual machine
Shut down virtual machine
Change 'maint' user password
Change time zone
Change NTP server
Enable SSH access
Increase jail disk size (/jail)
Upgrade
Install VMware Tools
Generate MFA TokenMFA is always enabled, you cannot disable MFA. -
Option 3: Network Configuration
Display or change IP address settings
Display or change domain name search settings
Display or change static routes
Commit changes
Ping a host -
Option 4: Support and Diagnostics
Generate support bundle
Access diagnostic shell
Enable remote diagnostic access
Generate core dump bundle
