Access the maintenance console
You can manage your application, system, and network configurations by using the maintenance console for SnapCenter Plug-in for VMware vSphere. You can change your administrator password, maintenance password, generate support bundles, and start remote diagnostics.
Before you begin
Before stopping and restarting the SnapCenter Plug-in for VMware vSphere service, you should suspend all schedules.
About this task
  • The defaults are “maint” as the username and “admin123” as the password to log in to the maintenance console for SnapCenter Plug-in for VMware vSphere.
    Tip After deployment, modify the default login credentials.
  • You must set a password for the “diag” user while enabling remote diagnostics.
    To obtain the root user permission to execute the command, use the sudo <command>.
Steps
  1. From the VMware vSphere web client, select the VM where the SnapCenter VMware plug-in is located.
  2. Right-click the VM, then on the Summary tab of the virtual appliance click Launch Remote Console to open a maintenance console window.
    The logon defaults for the SnapCenter VMware plug-in maintenance console are as follows:
    Username: maint
    Password: admin123
    Error: Missing Graphic Image
  3. You can perform the following operations:
    • Option 1: Application Configuration
      Display a summary of SnapCenter VMware plug-in
      Start or stop SnapCenter VMware plug-in service
      Change login username or password for SnapCenter VMware plug-in
      Change MySQL password
      Backup and restore MySQL
    • Option 2: System Configuration
      Reboot or shutdown virtual machine
      Change 'maint' user password
      Change time zone
      Change NTP server
      Enable/Disable SSH Access
      Increase jail disk size (/jail)
      Upgrade
      Install VMware Tools
    • Option 3: Network Configuration
      Display or change IP address settings
      Display or change domain name search settings
      Display or change static routes
      Commit changes
      Ping a host
    • Option 4: Support and Diagnostics
      Generate support bundle
      Access diagnostic shell
      Enable remote diagnostic access
      Generate core dump bundle
