Access reports
You can request reports for one or more jobs from the dashboard.
The Reports tab contains information on the jobs that are selected on the Jobs page in the Dashboard. If no jobs are selected, the Reports tab is blank.
From the vCenter client shortcut page, select SnapCenter Plug-in for VMware vSphere (SCV).
In the left navigation pane of SCV, select Dashboard > Reports tab.
For Backup Reports, you can do the following:
Modify the report
Select the filter icon to modify the time range, job status type, resource groups, and policies to be included in the report.
Generate a detailed report
Double-click any job to generate a detailed report for that job.
Optional: On the Reports tab, select Download and select the format (HTML or CSV).
You can also select the download icon to download plug-in logs.
Types of reports from the VMware vSphere client
The VMware vSphere client for SnapCenter provides customizable report options that provide you with details about your data protection jobs and plug-in resource status. You can generate reports for primary protection only.
Backup schedules are executed in the time zone in which SnapCenter Plug-in for VMware vSphere is deployed. vCenter reports data in the time zone in which the vCenter is located. Therefore, if the SnapCenter Plug-in for VMware vSphere and the vCenter are in different time zones, data in the VMware vSphere client Dashboard might not be the same as the data in the reports. |
The Dashboard displays information on migrated backups only after backups post-migration are performed.
| Report type | Description |
Backup Report |
Displays overview data about backup jobs. Select a section/status on the graph to see a list of jobs with that status on the Reports tab. |
Mount Report |
Displays overview data about mount jobs. Select a section/status on the graph to see a list of jobs with that status on the Reports tab. |
Restore Report |
Displays overview status information about restore jobs. Select a section/status on the graph to see a list of jobs with that status on the Reports tab. |
Last Protection Status of |
Displays overview information about the protection status, during the configured number of days, for VMs and datastores managed by the SnapCenter Plug-in for VMware vSphere. The default is 7 days. To modify the value in the properties file, refer to Modify configuration default values. |
