SnapCenter software
SnapCenter automation using REST APIs
You can use REST APIs to perform several SnapCenter management operations. REST APIs are exposed through the Swagger web page. You can access the Swagger web page available at https://<SnapCenter_IP_address_or_name>:<SnapCenter_port>/swagger/ to display the REST API documentation, as well as to manually issue an API call.
The plug-ins that support REST APIs are:
  • Plug-in for Microsoft SQL Server
  • Plug-in for SAP HANA Database
  • Plug-in for Oracle Database
For information on SnapCenter Plug-in for VMware vSphere REST APIs, see SnapCenter Plug-in for VMware vSphere REST APIs
