SnapCenter 4.8 cmdlets
Set-SmAuditSettings
Sets Audit configurations and Syslog configurations
Syntax
Set-SmAuditSettings [-MaxFileSize]  <Int64>  [-MaxSizeRollBackups]  <Int32>  [-AuditLogDirectory]  <String>  [-UniversalTime]  <Boolean>  [-AuditChecksumLogDirectory]  <String>  [-DiskSpaceLimitPercentage]  <Int32>  [-EnableAuditIntegrityCheckSchedule]  <Boolean>  [-EnableSyslogServer]  <Boolean>  [-SyslogServerHost]  <String>  [-SyslogServerPort]  <Int32>  [-SyslogProtocol]  <SyslogProtocols>  [-SyslogFormat]  <SyslogFormats>
Detailed Description
Sets below configurations Audit related configuration - Maximum File Size Maximum files to retain Audit Log file location Audit Log Checksum file location DiskSpaceLimitPercentage Option to Enable Audit Integrity Check Schedule Syslog server related configuration - Option to Enable Syslog Server Syslog Server Host Syslog Server Port Syslog Protocol Syslog Format
Name Description Required? Pipeline Input Default Value
MaxFileSize
The maximum size in MB that the log file is allowed to reach before being rolled over to backup files.
true
false
MaxSizeRollBackups
The number of roll over audit files that are retained.
true
false
AuditLogDirectory
The location where audit files are generated.
true
false
UniversalTime
Enables message logging in UTC time for installations in different geographical locations. Use $True to enable UniversalTime or $False to disable UniversalTime.
false
false
The location where audit checksum files are generated.
true
false
Disk space usage limit in percentage, after limit is reached alters are raised.
true
false
To Enable scheduled audit integrity check. Possible values are $True and $False.
true
false
EnableSyslogServer
Switch to Enable forwarding audit logs to syslog server.
true
false
SyslogServerHost
Syslog server IP address or Server name.
false
false
SyslogServerPort
Syslog server Port. Possible values can range between 0 - 65535.
false
false
SyslogProtocol
Syslog server Protocol. Possible values are UDP, TCP and TLS12.
false
false
SyslogFormat
Syslog server messages format. Possible values are Rfc5424 and Rfc3164.
false
false
Example 1: Setting audit log and syslog server settings
 Set-SmAuditSettings -MaxFileSize 50
-MaxSizeRollBackups 10
-AuditLogDirectory 'C:\Program Files\NetApp\SnapCenter WebApp\audit'
-AuditChecksumLogDirectory 'C:\Program Files\NetApp\SnapCenter WebApp\auditChecksum'
-DiskSpaceLimitPercentage 80
-EnableAuditIntegrityCheckSchedule $False
-EnableSyslogServer
-SyslogServerHost 10.229.39.107
-SyslogServerPort 1468
-SyslogProtocol TCP
-SyslogFormat Rfc5424
This example sets audit log and syslog server settings.
MaxFileSize : 50
MaxSizeRollBackups : 10
UniversalTime : False
AuditLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\audit
AuditChecksumLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\auditChecksum
DiskSpaceLimitPercentage : 80
EnableAuditIntegrityCheckSchedule : False
EnableSyslogServer : True
SyslogServerHost : 10.229.39.107
SyslogServerPort : 1468
SyslogProtocol : TCP
SyslogFormat : Rfc5424
