Get-SdPortSet
Gets information about available portsets.
Syntax
Get-SdPortSet [-PortSetName] <String> [-StorageSystem] <String> [-GetLunMappings] <> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
PortSetName |
Specifies the name of the portset about which you want to get information. |
false |
true (ByPropertyName) |
StorageSystem |
Specifies the name of the storage system on which your portset resides. |
true |
GetLunMappings |
Indicates that you want to get information about the number of LUN mappings. |
false |
Session |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
