Uncatalog-SmBackupWithOracleRMAN
Uncatalog Oracle backup(s).
Syntax
Uncatalog-SmBackupWithOracleRMAN [-PluginCode] <PluginCode> [-BackupIds] <String> [-BackupNames] <String> [-AppObjectId] <String>
Detailed Description
Uncatalogs the Oracle Database backup(s) in SnapCenter with Oracle Recovery Manager (RMAN).
| Name | Description | Required? | Pipeline Input | Default Value |
PluginCode |
Specifies the plug-in code of the resource to be cataloged. |
true |
false |
BackupIds |
Specifies the id of backup that need to be uncataloged. Multiple backup ids can be specified in a comma separated list. |
false |
false |
BackupNames |
Specifies the name of the backup that need to be uncataloged. Multiple backup names can be specified in a comma separated list. |
false |
false |
AppObjectId |
Specifies the ID of the application object. |
false |
true (ByPropertyName) |
Example 1: Uncataloging a SCO backup using backupId
Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupId 7
This example syntax uncatalogs a SCO backup using backupId.
Name: Uncataloging Backup(s)
scspr1894465002_gdl_englab_netapp_com_TSPITRDB_scspr1894465002_08-06-2020_01.13.03.7681_1
StartTime : 8/7/2020 2:11:00 AM
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 29
ApisJobKey :
ObjectId: 0
PluginCode : SCO
PluginName : SnapCenter Plug-in for Oracle Database
HostId : 0
RoleId :
JobIds : {}
Example 2: Uncataloging a SCO backup using backupname
Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupName scspr1894465002_gdl_englab_netapp_com_TSPITRDB_scspr1894465002_08-06-2020_04.13.23.4083_1
This example syntax uncatalogs a SCO backup using backupname.
StartTime : 8/7/2020 2:05:40 AM
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 29
ApisJobKey :
ObjectId: 0
PluginCode : SCO
HostId : 0
RoleId :
JobIds : {}
Example 3: Uncataloging a SCO backup for the desired database
Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupName rg1_galaxy-vm134_08-08-2020_15.11.16.3564_0 -AppObjectId 'galaxy-vm134.gdl.englab.netapp.com\DB14'
This example syntax uncatalogs a SCO backup for the desired database.
rg1_galaxy-vm134_08-08-2020_15.11.16.3564_1
StartTime : 8/7/2020 2:10:40 AM
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 29
ApisJobKey :
ObjectId: 0
PluginCode : SCO
HostId : 0
RoleId :
JobIds : {}
