• Installation and Setup for UNIX for Clustered Data ONTAP
    • Product overview
    • Preparing for deployment
    • Configuring databases
    • Setting up SnapManager
    • Preparing storage systems for SnapMirror and SnapVault replication
    • Backing up and verifying your databases
  • Installation and Setup for UNIX for Data ONTAP Operating in 7-mode
    • Product overview
  • Administration for UNIX
    • Product overview
      • Recommended general database layouts and storage configurations
        • Support for ASM databases without ASMLib
          • Deploying and running the scripts
      • Limitations when working with SnapManager
        • Limitations related to Oracle Database
    • Upgrading SnapManager
      • Post-upgrade tasks
      • Upgrading SnapManager hosts by using rolling upgrade
        • What a rollback is
    • Configuring SnapManager
      • SnapManager configuration parameters
    • Security and credential management
      • About role-based access control
      • Clearing user credentials for all hosts, repositories, and profiles
      • Deleting credentials for individual resources
    • Managing profiles for efficient backups
    • Backing up databases
      • What full and partial backups are
      • Creating database backups
      • What AutoSupport is
      • Changing the backup retention policy
    • Scheduling database backups
    • Restoring database backups
      • What database restore is
        • Guidelines for when you can use fast restore
      • Restore files from an alternate location
        • Restore backups from an alternate location overview
    • Cloning database backup
      • Creating clone specifications
      • Considerations for cloning a database to an alternate host
      • Splitting a clone
    • Introduction to data protection in SnapManager
      • Configuring and enabling policy-driven data protection
      • Considerations for performing data protection
      • Restoring protected backups from secondary storage
    • SnapManager for Oracle uses Protection Manager to protect a database backup
      • Protected backup configuration and execution
      • Database restoration from backup
    • Performing management operations
    • Configuring an email notification
      • Configuring email notification for a new profile
      • Configuring email notification for an existing profile
    • Creating task specification file and scripts for SnapManager operations
      • Creating pretask, post-task, and policy scripts
    • Updating storage system name and target database host name associated with a profile
    • Maintaining history of SnapManager operations
    • SnapManager for Oracle command reference
    • Troubleshooting SnapManager
      • Dump files
  • Installation and Setup for Windows
    • What SnapManagerfor Oracle is
      • Advantages of using SnapManager
      • What the SnapManager for Oracle architecture is
    • SnapManager for Oracle deployment considerations
      • Requirements for running SnapManager
      • Database version support and configuration overview
    • Installing SnapManager for Oracle
      • Preparing to install SnapManager for Oracle
    • Starting SnapManagerfor Oracle
      • Accessing SnapManager
        • Starting the SnapManager host server
      • Verifying the environment
      • Creating repositories
      • Protecting database backups by using postscripts
        • Creating or updating the post scripts
          • Creating post-processing, task-specification files
      • Dump files
