SolidFire Active IQ
Select a cluster
You can view cluster information for a specific cluster when you select a cluster from the Select a Cluster drop-down list. Each category of cluster information is presented in either a table format or a graphical format.
Learn about the various lists and filters available from the Dashboard cluster overview or the Reporting drop-down menu in the side panel:
Find more information
