View IP addresses in StorageGRID
You can view the IP address for each grid node in your StorageGRID system. You can then use this IP address to log in to the grid node at the command line and perform various maintenance procedures.
Before you begin
You are signed in to the Grid Manager using a supported web browser.
About this task
For information about changing IP addresses, see Configure IP addresses.
Steps
Select Nodes > grid node > Overview.
Select Show more to the right of the IP Addresses title.
The IP addresses for that grid node are listed in a table.
