Obtain required materials for a StorageGRID hotfix
Before applying a hotfix, you must obtain all required materials.
Item Notes
StorageGRID hotfix file
You must download the StorageGRID hotfix file.
recovery package (.zip) file
Before applying a hotfix, download the most recent recovery package file in case any problems occur during the hotfix. Then, after the hotfix has been applied, download a new copy of the recovery package file and save it in a safe location. The updated recovery package file allows you to restore the system if a failure occurs.
Passwords.txt file
Optional and used only if you are applying a hotfix manually using the SSH client. The Passwords.txt file is part of the recovery package .zip file.
Provisioning passphrase
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not listed in the Passwords.txt file.
Related documentation
readme.txt file for the hotfix. This file is included on the hotfix download page. Be sure to review the readme file carefully before applying the hotfix.
