Remove custom alert rules in StorageGRID
You can remove a custom alert rule if you no longer want to use it.
Before you begin
You are signed in to the Grid Manager using a supported web browser.
You have the Manage alerts or Root access permission.
Steps
Select Alerts > Rules.
The Alert Rules page appears.
Select the radio button for the custom alert rule you want to remove.
You can't remove a default alert rule.
Select Remove custom rule.
A confirmation dialog box appears.
Select OK to remove the alert rule.
Any active instances of the alert will be resolved within 10 minutes.
