External communications for StorageGRID
Contributors netapp-pcarriga
Clients need to communicate with grid nodes to ingest and retrieve content. The ports used depends on the object storage protocols chosen. These ports need to be accessible to the client.
Restricted access to ports
If enterprise networking policies restrict access to any of the ports, you can do one of the following:
  • Use load balancer endpoints to allow access on user-defined ports.
  • Remap ports when deploying nodes. However, you should not remap load balancer endpoints. See the information about port remapping for your StorageGRID node:
Note Support for port remapping is deprecated and will be removed in a future release. To remove remapped ports, refer to Remove port remaps on StorageGRID appliances or Remove port remaps on bare metal hosts.
Ports used for external communications
The following table shows the ports used for traffic into the nodes.
Note This list does not include ports that might be configured as load balancer endpoints.
Port TCP or UDP Protocol From To Details
22
TCP
SSH
Service laptop
All nodes
SSH or console access is required for procedures with console steps. Optionally, you can use port 2022 instead of 22.
Note: This port is only required when you need to enable SSH access for certain maintenance operations.
25
TCP
SMTP
Admin Nodes
Email server
Used for alerts and email-based AutoSupport. You can override the default port setting of 25 using the Email Servers page.
53
TCP/ UDP
DNS
All nodes
DNS servers
Used for DNS.
67
UDP
DHCP
All nodes
DHCP service
Optionally used to support DHCP-based network configuration. The dhclient service does not run for statically-configured grids.
68
UDP
DHCP
DHCP service
All nodes
Optionally used to support DHCP-based network configuration. The dhclient service does not run for grids that use static IP addresses.
80
TCP
HTTP
Browser
Admin Nodes
Port 80 redirects to port 443 for the Admin Node user interface.
80
TCP
HTTP
Browser
Appliances
Port 80 redirects to port 8443 for the StorageGRID Appliance Installer.
80
TCP
HTTP
Storage Nodes with ADC
AWS
Used for platform services messages sent to AWS or other external services that use HTTP. Tenants can override the default HTTP port setting of 80 when creating an endpoint.
80
TCP
HTTP
Storage Nodes
AWS
Cloud Storage Pools requests sent to AWS targets that use HTTP. Grid administrators can override the default HTTP port setting of 80 when configuring a Cloud Storage Pool.
123
UDP
NTP
Primary NTP nodes
External NTP
Network time protocol service. Nodes selected as primary NTP sources also synchronize clock times with the external NTP time sources.
161
TCP/ UDP
SNMP
SNMP client
All nodes
Used for SNMP polling. All nodes provide basic information; Admin Nodes also provide alert data. Defaults to UDP port 161 when configured.
Note: This port is only required, and is only opened on the node firewall if SNMP is configured. If you plan to use SNMP, you can configure alternate ports.
Note: For information about using SNMP with StorageGRID, contact your NetApp account representative.
162
TCP/ UDP
SNMP Notifications
All nodes
Notification destinations
Outbound SNMP notifications and traps default to UDP port 162.
Note: This port is only required if SNMP is enabled and notification destinations are configured. If you plan to use SNMP, you can configure alternate ports.
389
TCP/ UDP
LDAP
Active Directory/LDAP
Used for connecting to an Active Directory or LDAP server for Identity Federation.
443
TCP
HTTPS
Browser
Admin Nodes
Used by web browsers and management API clients to access the Grid Manager and Tenant Manager.
Note: If you close Grid Manager ports 443 or 8443, any users currently connected on a blocked port, including you, will lose access to Grid Manager unless their IP address has been added to the Privileged address list. Refer to Configure firewall controls to configure privileged IP addresses.
443
TCP
HTTPS
Admin Nodes
Active Directory
Used by Admin Nodes connecting to Active Directory if single sign-on (SSO) is enabled.
443
TCP
HTTPS
AWS
Used for platform services messages sent to AWS or other external services that use HTTPS. Tenants can override the default HTTP port setting of 443 when creating an endpoint.
443
TCP
HTTPS
Storage Nodes
AWS
Cloud Storage Pools requests sent to AWS targets that use HTTPS. Grid administrators can override the default HTTPS port setting of 443 when configuring a Cloud Storage Pool.
636
TCP/ UDP
LDAP
5353
UDP
mDNS
All nodes
All nodes
Provides the multicast DNS (mDNS) service used for full-grid IP changes and for primary Admin Node discovery during installation, expansion, and recovery.
Note: Configuring this port is optional.
5696
TCP
KMIP
Appliance
KMS
Key Management Interoperability Protocol (KMIP) external traffic from appliances configured for node encryption to the Key Management Server (KMS), unless a different port is specified on the KMS configuration page of the StorageGRID Appliance Installer.
8443
TCP
HTTPS
Browser
Admin Nodes
Optional. Used by web browsers and management API clients to access the Grid Manager. Can be used to separate Grid Manager and Tenant Manager communications.
Note: If you close Grid Manager ports 443 or 8443, any users currently connected on a blocked port, including you, lose access to Grid Manager unless their IP address has been added to the Privileged address list. Refer to Configure firewall controls to configure privileged IP addresses.
8443
TCP
HTTPS
Browser
Appliances
Used by web browsers and management API clients to access the StorageGRID Appliance Installer.
Note: Port 443 redirects to port 8443 for the StorageGRID Appliance Installer.
9022
TCP
SSH
Service laptop
Appliances
Grants access to StorageGRID appliances in pre-configuration mode for support and troubleshooting. This port is not required to be accessible between grid nodes or during normal operations.
9091
TCP
HTTPS
External Grafana service
Admin Nodes
Used by external Grafana services for secure access to the StorageGRID Prometheus service.
Note: This port is required only if certificate-based Prometheus access is enabled.
9092
TCP
Kafka
Kafka cluster
Used for platform services messages sent to a Kafka cluster. Tenants can override the default Kafka port setting of 9092 when creating an endpoint.
9443
TCP
HTTPS
Browser
Admin Nodes
Optional. Used by web browsers and management API clients to access the Tenant Manager. Can be used to separate Grid Manager and Tenant Manager communications.
18082
TCP
HTTPS
S3 clients
Storage Nodes
S3 client traffic directly to Storage Nodes (HTTPS).
18084
TCP
HTTP
S3 clients
Storage Nodes
S3 client traffic directly to Storage Nodes (HTTP).
23000-23999
TCP
HTTPS
All nodes on the source grid for cross-grid replication
Admin Nodes and Gateway Nodes on the destination grid for cross-grid replication
This range of ports is reserved for grid federation connections. Both grids in a given connection use the same port.
