Automate the deployment of grid nodes in StorageGRID with VMware vSphere
You can use the VMware OVF Tool to automate the deployment of grid nodes. You can also automate the configuration of StorageGRID.
Automate grid node deployment
Use the VMware OVF Tool to automate the deployment of grid nodes.
Before you begin
  • You have access to a Linux/Unix system with Bash 3.2 or later.
  • You have VMware vSphere with vCenter
  • You have VMware OVF Tool installed and correctly configured.
  • You know the username and password to access VMware vSphere using the OVF Tool
  • You have the sufficient permissions to deploy VMs from OVF files and power them on, and permissions to create additional volumes to attach to the VMs. See the ovftool documentation for details.
  • You know the virtual infrastructure (VI) URL for the location in vSphere where you want to deploy the StorageGRID virtual machines. This URL will typically be a vApp, or Resource Pool. For example: vi://vcenter.example.com/vi/sgws
    Note You can use the VMware ovftool utility to determine this value (see the ovftool documentation for details).
    Note If you are deploying to a vApp, the virtual machines will not start automatically the first time, and you must power them on manually.
  • You have collected all the required information for the deployment configuration file. See Collect information about your deployment environment for information.
  • You have access to the following files from the VMware installation archive for StorageGRID:
Filename Description
NetApp-SG-version-SHA.vmdk
The virtual machine disk file that is used as a template for creating grid node virtual machines.
Note: This file must be in the same folder as the .ovf and .mf files.
vsphere-primary-admin.ovf
vsphere-primary-admin.mf
The Open Virtualization Format template file (.ovf) and manifest file (.mf) for deploying the primary Admin Node.
vsphere-non-primary-admin.ovf
vsphere-non-primary-admin.mf
The template file (.ovf) and manifest file (.mf) for deploying non-primary Admin Nodes.
vsphere-gateway.ovf
vsphere-gateway.mf
The template file (.ovf) and manifest file (.mf) for deploying Gateway Nodes.
vsphere-storage.ovf
vsphere-storage.mf
The template file (.ovf) and manifest file (.mf) for deploying virtual machine-based Storage Nodes.
deploy-vsphere-ovftool.sh
The Bash shell script used to automate the deployment of virtual grid nodes.
deploy-vsphere-ovftool-sample.ini
The example configuration file for use with the deploy-vsphere-ovftool.sh script.
Define the configuration file for your deployment
You specify the information needed to deploy virtual grid nodes for StorageGRID in a configuration file, which is used by the deploy-vsphere-ovftool.sh Bash script. You can modify an example configuration file, so that you don't have to create the file from scratch.
Steps
  1. Make a copy of the example configuration file (deploy-vsphere-ovftool.sample.ini). Save the new file as deploy-vsphere-ovftool.ini in the same directory as deploy-vsphere-ovftool.sh.
  2. Open deploy-vsphere-ovftool.ini.
  3. Enter all of the information required to deploy VMware virtual grid nodes.
    See Configuration file settings for information.
  4. When you have entered and verified all of the necessary information, save and close the file.
The deploy-vsphere-ovftool.ini configuration file contains the settings that are required to deploy virtual grid nodes.
The configuration file first lists global parameters, and then lists node-specific parameters in sections defined by node name. When the file is used:
  • Global parameters are applied to all grid nodes.
  • Node-specific parameters override global parameters.
Global parameters
Global parameters are applied to all grid nodes, unless they are overridden by settings in individual sections. Place the parameters that apply to multiple nodes in the global parameter section, and then override these settings as necessary in the sections for individual nodes.
  • OVFTOOL_ARGUMENTS: You can specify OVFTOOL_ARGUMENTS as global settings, or you can apply arguments individually to specific nodes. For example:
    OVFTOOL_ARGUMENTS = --powerOn --noSSLVerify --diskMode=eagerZeroedThick --datastore='datastore_name'
    You can use the --powerOffTarget and --overwrite options to shut down and replace existing virtual machines.
    Caution You should deploy nodes to different datastores and specify OVFTOOL_ARGUMENTS for each node, instead of globally.
  • SOURCE: The path to the StorageGRID virtual machine template (.vmdk) file and the .ovf and .mf files for individual grid nodes. This defaults to the current directory.
    SOURCE = /downloads/StorageGRID-Webscale-version/vsphere
  • TARGET: The VMware vSphere virtual infrastructure (vi) URL for the location where StorageGRID will be deployed. For example:
    TARGET = vi://vcenter.example.com/vm/sgws
  • GRID_NETWORK_CONFIG: The method used to acquire IP addresses, either STATIC or DHCP. The default is STATIC. If all or most of the nodes use the same method for acquiring IP addresses, you can specify that method here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    GRID_NETWORK_CONFIG = STATIC
  • GRID_NETWORK_TARGET: The name of an existing VMware network to use for the Grid Network. If all or most of the nodes use the same network name, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    GRID_NETWORK_TARGET = SG Admin Network
  • GRID_NETWORK_MASK: The network mask for the Grid Network. If all or most of the nodes use the same network mask, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    GRID_NETWORK_MASK = 255.255.255.0
  • GRID_NETWORK_GATEWAY: The network gateway for the Grid Network. If all or most of the nodes use the same network gateway, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    GRID_NETWORK_GATEWAY = 10.1.0.1
  • GRID_NETWORK_MTU: Optional. The maximum transmission unit (MTU) on the Grid Network. If specified, the value must be between 1280 and 9216. For example:
    GRID_NETWORK_MTU = 9000
    If omitted, 1400 is used.
    If you want to use jumbo frames, set the MTU to a value suitable for jumbo frames, such as 9000. Otherwise, keep the default value.
    Note The MTU value of the network must match the value configured on the virtual switch port in vSphere that the node is connected to. Otherwise, network performance issues or packet loss might occur.
    Note For the best network performance, all nodes should be configured with similar MTU values on their Grid Network interfaces. The Grid Network MTU mismatch alert is triggered if there is a significant difference in MTU settings for the Grid Network on individual nodes. The MTU values don't have to be the same for all network types.
  • ADMIN_NETWORK_CONFIG: The method used to acquire IP addresses, either DISABLED, STATIC, or DHCP. The default is DISABLED. If all or most of the nodes use the same method for acquiring IP addresses, you can specify that method here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    ADMIN_NETWORK_CONFIG = STATIC
  • ADMIN_NETWORK_TARGET: The name of an existing VMware network to use for the Admin Network. This setting is required unless the Admin Network is disabled. If all or most of the nodes use the same network name, you can specify it here. Unlike the Grid Network, all nodes do not need to be connected to the same Admin Network. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    ADMIN_NETWORK_TARGET = SG Admin Network
  • ADMIN_NETWORK_MASK: The network mask for the Admin Network. This setting is required if you are using static IP addressing. If all or most of the nodes use the same network mask, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    ADMIN_NETWORK_MASK = 255.255.255.0
  • ADMIN_NETWORK_GATEWAY: The network gateway for the Admin Network. This setting is required if you are using static IP addressing and you specify external subnets in the ADMIN_NETWORK_ESL setting. (That is, it is not required if ADMIN_NETWORK_ESL is empty.) If all or most of the nodes use the same network gateway, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    ADMIN_NETWORK_GATEWAY = 10.3.0.1
  • ADMIN_NETWORK_ESL: The external subnet list (routes) for the Admin Network, specified as a comma-separated list of CIDR route destinations. If all or most of the nodes use the same external subnet list, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    ADMIN_NETWORK_ESL = 172.16.0.0/21,172.17.0.0/21
  • ADMIN_NETWORK_MTU: Optional. The maximum transmission unit (MTU) on the Admin Network. Don't specify if ADMIN_NETWORK_CONFIG = DHCP. If specified, the value must be between 1280 and 9216. If omitted, 1400 is used. If you want to use jumbo frames, set the MTU to a value suitable for jumbo frames, such as 9000. Otherwise, keep the default value. If all or most of the nodes use the same MTU for the Admin Network, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    ADMIN_NETWORK_MTU = 8192
  • CLIENT_NETWORK_CONFIG: The method used to acquire IP addresses, either DISABLED, STATIC, or DHCP. The default is DISABLED. If all or most of the nodes use the same method for acquiring IP addresses, you can specify that method here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    CLIENT_NETWORK_CONFIG = STATIC
  • CLIENT_NETWORK_TARGET: The name of an existing VMware network to use for the Client Network. This setting is required unless the Client Network is disabled. If all or most of the nodes use the same network name, you can specify it here. Unlike the Grid Network, all nodes do not need to be connected to the same Client Network. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    CLIENT_NETWORK_TARGET = SG Client Network
  • CLIENT_NETWORK_MASK: The network mask for the Client Network. This setting is required if you are using static IP addressing. If all or most of the nodes use the same network mask, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    CLIENT_NETWORK_MASK = 255.255.255.0
  • CLIENT_NETWORK_GATEWAY: The network gateway for the Client Network. This setting is required if you are using static IP addressing. If all or most of the nodes use the same network gateway, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    CLIENT_NETWORK_GATEWAY = 10.4.0.1
  • CLIENT_NETWORK_MTU: Optional. The maximum transmission unit (MTU) on the Client Network. Don't specify if CLIENT_NETWORK_CONFIG = DHCP. If specified, the value must be between 1280 and 9216. If omitted, 1400 is used. If you want to use jumbo frames, set the MTU to a value suitable for jumbo frames, such as 9000. Otherwise, keep the default value. If all or most of the nodes use the same MTU for the Client Network, you can specify it here. You can then override the global setting by specifying different settings for one or more individual nodes. For example:
    CLIENT_NETWORK_MTU = 8192
  • PORT_REMAP: Remaps any port used by a node for internal grid node communications or external communications. Remapping ports is necessary if enterprise networking policies restrict one or more ports used by StorageGRID. For the list of ports used by StorageGRID, see internal grid node communications and external communications in Networking guidelines.
    Note Don't remap the ports you are planning to use to configure load balancer endpoints.
    Note If only PORT_REMAP is set, the mapping that you specify is used for both inbound and outbound communications. If PORT_REMAP_INBOUND is also specified, PORT_REMAP applies only to outbound communications.
    The format used is: network type/protocol/default port used by grid node/new port, where network type is grid, admin, or client, and protocol is tcp or udp.
    For example:
    PORT_REMAP = client/tcp/18082/443
    If used alone, this example setting symmetrically maps both inbound and outbound communications for the grid node from port 18082 to port 443. If used in conjunction with PORT_REMAP_INBOUND, this example setting maps outbound communications from port 18082 to port 443.
    You can also remap multiple ports using a comma-separated list.
    For example:
    PORT_REMAP = client/tcp/18082/443, client/tcp/18083/80
  • PORT_REMAP_INBOUND: Remaps inbound communications for the specified port. If you specify PORT_REMAP_INBOUND but don't specify a value for PORT_REMAP, outbound communications for the port are unchanged.
    The format used is: network type/protocol/_default port used by grid node/new port, where network type is grid, admin, or client, and protocol is tcp or udp.
    For example:
    PORT_REMAP_INBOUND = client/tcp/443/18082
    This example takes traffic that is sent to port 443 to pass an internal firewall and directs it to port 18082, where the grid node is listening for S3 requests.
    You can also remap multiple inbound ports using a comma-separated list.
    For example:
    PORT_REMAP_INBOUND = grid/tcp/3022/22, admin/tcp/3022/22
  • TEMPORARY_PASSWORD_TYPE: The type of temporary installation password to be used when accessing the VM console or the StorageGRID Installation API, or using SSH, before the node joins the grid.
    Tip If all or most of the nodes use the same type of temporary installation password, specify the type in the global parameter section. Then, optionally use a different setting for an individual node. For example, if you select Use Custom Password globally, you can use CUSTOM_TEMPORARY_PASSWORD=<password> to set the password for each node.
    TEMPORARY_PASSWORD_TYPE can be one of the following:
    • Use node name: The node name is used as the temporary installation password and provides access to VM console, the StorageGRID Installation API, and SSH.
    • Disable password: No temporary installation password will be used. If you need to access the VM to debug installation issues, see Troubleshoot installation issues.
    • Use custom password: The value provided with CUSTOM_TEMPORARY_PASSWORD=<password> is used as the temporary installation password and provides access to VM console, the StorageGRID Installation API, and SSH.
      Tip Optionally, you can omit the TEMPORARY_PASSWORD_TYPE parameter and only specify CUSTOM_TEMPORARY_PASSWORD=<password>.
  • CUSTOM_TEMPORARY_PASSWORD=<password> Optional. The temporary password to use during installation when accessing VM console, the StorageGRID Installation API, and SSH. Ignored if TEMPORARY_PASSWORD_TYPE is set to Use node name or Disable password.
Each node is in its own section of the configuration file. Each node requires the following settings:
  • The section head defines the node name that will be displayed in the Grid Manager. You can override that value by specifying the optional NODE_NAME parameter for the node.
  • NODE_TYPE: VM_Admin_Node, VM_Storage_Node, or VM_API_Gateway_Node
  • STORAGE_TYPE: combined, data, or metadata. This optional parameter for storage nodes defaults to combined (data and metadata) if it is not specified. For more information, see Types of Storage Nodes.
  • GRID_NETWORK_IP: The IP address for the node on the Grid Network.
  • ADMIN_NETWORK_IP: The IP address for the node on the Admin Network. Required only if the node is attached to the Admin Network and ADMIN_NETWORK_CONFIG is set to STATIC.
  • CLIENT_NETWORK_IP: The IP address for the node on the Client Network. Required only if the node is attached to the Client Network and CLIENT_NETWORK_CONFIG for this node is set to STATIC.
  • ADMIN_IP: The IP address for the primary Admin node on the Grid Network. Use the value that you specify as the GRID_NETWORK_IP for the primary Admin Node. If you omit this parameter, the node attempts to discover the primary Admin Node IP using mDNS. For more information, see How grid nodes discover the primary Admin Node.
    Note The ADMIN_IP parameter is ignored for the primary Admin Node.
  • Any parameters that were not set globally. For example, if a node is attached to the Admin Network and you did not specify ADMIN_NETWORK parameters globally, you must specify them for the node.
Primary Admin Node
The following additional settings are required for the primary Admin Node:
  • ADMIN_ROLE: Primary
This example entry is for a primary Admin Node that is on all three networks:
[DC1-ADM1]
  ADMIN_ROLE = Primary
  NODE_TYPE = VM_Admin_Node
  TEMPORARY_PASSWORD_TYPE = Use custom password
  CUSTOM_TEMPORARY_PASSWORD = Passw0rd
  GRID_NETWORK_IP = 10.1.0.2
  ADMIN_NETWORK_IP = 10.3.0.2
  CLIENT_NETWORK_IP = 10.4.0.2
The following additional setting is optional for the primary Admin Node:
  • DISK: By default, Admin Nodes are assigned two additional 200 GB hard disks for audit and database use. You can increase these settings using the DISK parameter. For example:
    DISK = INSTANCES=2, CAPACITY=300
Note For Admin nodes, INSTANCES must always equal 2.
Storage Node
The following additional setting is required for Storage Nodes:
  • NODE_TYPE: VM_Storage_Node
    This example entry is for a Storage Node that is on the Grid and Admin Networks, but not on the Client Network. This node uses the ADMIN_IP setting to specify the primary Admin Node's IP address on the Grid Network.
    [DC1-S1]
      NODE_TYPE = VM_Storage_Node
      GRID_NETWORK_IP = 10.1.0.3
      ADMIN_NETWORK_IP = 10.3.0.3
      ADMIN_IP = 10.1.0.2
    This second example entry is for a Storage Node on a Client Network where the customer's enterprise networking policy states that an S3 client application is only permitted to access the Storage Node using either port 80 or 443. The example configuration file uses PORT_REMAP to enable the Storage Node to send and receive S3 messages on port 443.
    [DC2-S1]
      GRID_NETWORK_IP = 10.1.1.3
      CLIENT_NETWORK_IP = 10.4.1.3
      ADMIN_IP = 10.1.0.2
    The last example creates a symmetric remapping for ssh traffic from port 22 to port 3022, but explicitly sets the values for both inbound and outbound traffic.
    [DC1-S3]
      PORT_REMAP = grid/tcp/22/3022
      ADMIN_IP = 10.1.0.2
The following additional settings are optional for Storage Nodes:
  • DISK: By default, Storage Nodes are assigned three 4 TB disks for RangeDB use. You can increase these settings with the DISK parameter. For example:
    DISK = INSTANCES=16, CAPACITY=4096
  • STORAGE_TYPE: By default, all new Storage Nodes are configured to store both object data and metadata, known as a combined Storage Node. You can change the Storage Node type to store only data or metadata with the STORAGE_TYPE parameter. For example:
    STORAGE_TYPE = data
Gateway Node
The following additional setting is required for Gateway Nodes:
  • NODE_TYPE: VM_API_Gateway
This example entry is for an example Gateway Node on all three networks. In this example, no Client Network parameters were specified in the global section of the configuration file, so they must be specified for the node:
[DC1-G1]
  NODE_TYPE = VM_API_Gateway
  GRID_NETWORK_IP = 10.1.0.5
  ADMIN_NETWORK_IP = 10.3.0.5
  CLIENT_NETWORK_IP = 10.4.0.5
  ADMIN_IP = 10.1.0.2
Non-primary Admin Node
The following additional settings are required for non-primary Admin Nodes:
  • ADMIN_ROLE: Non-Primary
This example entry is for a non-primary Admin Node that is not on the Client Network:
[DC2-ADM1]
  ADMIN_ROLE = Non-Primary
  GRID_NETWORK_TARGET = SG Grid Network
  GRID_NETWORK_IP = 10.1.0.6
  ADMIN_NETWORK_IP = 10.3.0.6
  ADMIN_IP = 10.1.0.2
The following additional setting is optional for non-primary Admin Nodes:
Run the Bash script
You can use the deploy-vsphere-ovftool.sh Bash script and the deploy-vsphere-ovftool.ini configuration file you modified to automate the deployment of StorageGRID nodes in VMware vSphere.
Before you begin
You have created a deploy-vsphere-ovftool.ini configuration file for your environment.
You can use the help available with the Bash script by entering the help commands (-h/--help). For example:
./deploy-vsphere-ovftool.sh -h
or
./deploy-vsphere-ovftool.sh --help
Steps
  1. Log in to the Linux machine you are using to run the Bash script.
  2. Change to the directory where you extracted the installation archive.
    For example:
    cd StorageGRID-Webscale-version/vsphere
  3. To deploy all grid nodes, run the Bash script with the appropriate options for your environment.
    For example:
    ./deploy-vsphere-ovftool.sh --username=user --password=pwd ./deploy-vsphere-ovftool.ini
  4. If a grid node failed to deploy because of an error, resolve the error and rerun the Bash script for only that node.
    For example:
    ./deploy-vsphere-ovftool.sh --username=user --password=pwd --single-node="DC1-S3" ./deploy-vsphere-ovftool.ini
The deployment is complete when the status for each node is "Passed."
Deployment Summary
| node                        | attempts | status               |
| DC1-ADM1                    |        1 | Passed               |
| DC1-G1                      |        1 | Passed               |
| DC1-S1                      |        1 | Passed               |
| DC1-S2                      |        1 | Passed               |
| DC1-S3                      |        1 | Passed               |
Automate the configuration of StorageGRID
After deploying the grid nodes, you can automate the configuration of the StorageGRID system.
Before you begin
  • You know the location of the following files from the installation archive.
    configure-storagegrid.py
    Python script used to automate the configuration
    configure-storagegrid.sample.json
    Example configuration file for use with the script
    configure-storagegrid.blank.json
    Blank configuration file for use with the script
  • You have created a configure-storagegrid.json configuration file. To create this file, you can modify the example configuration file (configure-storagegrid.sample.json) or the blank configuration file (configure-storagegrid.blank.json).
Caution Store the management password and provisioning passphrase from the passwords section of the modified configure-storagegrid.json configuration file in a secure location. These passwords are required for installation, expansion, and maintenance procedures. You should also back up the modified configure-storagegrid.json configuration file and store it in a secure location.
About this task
You can use the configure-storagegrid.py Python script and the configure-storagegrid.json grid configuration file to automate the configuration of your StorageGRID system.
Note You can also configure the system using the Grid Manager or the Installation API.
Steps
  1. Log in to the Linux machine you are using to run the Python script.
    For example:
    cd StorageGRID-Webscale-version/platform
    where platform is debs, rpms, or vsphere.
  3. Run the Python script and use the configuration file you created.
    For example:
    ./configure-storagegrid.py ./configure-storagegrid.json --start-install
Result
A Recovery Package .zip file is generated during the configuration process, and it is downloaded to the directory where you are running the installation and configuration process. You must back up the Recovery Package file so that you can recover the StorageGRID system if one or more grid nodes fails. For example, copy it to a secure, backed up network location and to a secure cloud storage location.
Caution The Recovery Package file must be secured because it contains encryption keys and passwords that can be used to obtain data from the StorageGRID system.
If you specified that random passwords should be generated, open the Passwords.txt file and look for the passwords required to access your StorageGRID system.
##### The StorageGRID "Recovery Package" has been downloaded as: #####
#####           ./sgws-recovery-package-994078-rev1.zip          #####
#####   Safeguard this file as it will be needed in case of a    #####
#####                 StorageGRID node recovery.                 #####
Your StorageGRID system is installed and configured when a confirmation message is displayed.
StorageGRID has been configured and installed.
