Obtain the required materials for a StorageGRID software upgrade
Before you begin the software upgrade, obtain all required materials.
Item Notes
Service laptop
The service laptop must have:
  • Network port
  • SSH client (for example, PuTTY)
Browser support typically changes for each StorageGRID release. Make sure your browser is compatible with the new StorageGRID version.
Provisioning passphrase
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not listed in the Passwords.txt file.
Linux RPM or DEB archive
If any nodes are deployed on Linux hosts, you must download and install the RPM or DEB package on all hosts before you start the upgrade.
Ensure your Linux operating system meets StorageGRID's minimum kernel version requirements. See Install StorageGRID on Linux hosts.
StorageGRID documentation
