Replace NIC in an SG120 or SG1200
You might need to replace a Network Interface Card (NIC) in the SG120 or SG1200 if it is not functioning optimally or if it has failed.
To prevent service interruptions, confirm that all other Storage Nodes are connected to the grid before starting the Network Interface Card (NIC) replacement or replace the NIC during a scheduled maintenance window when periods of service disruption are acceptable. See the information about monitoring node connection states.
You have the correct replacement NIC.
You have physically located the SG120 or SG1200 appliance where you are replacing the NIC in the data center.
A controlled shutdown of the appliance is required before removing the appliance from the rack. -
You have disconnected all cables and removed the appliance cover.
You have determined the location of the NIC to replace.
The three NICs in the appliance are in three riser assemblies in the following positions in the chassis (rear of appliance with top cover removed shown):
Device or Part name Description 1
NIC 1 in the one-slot riser assembly
10/25-GbE Ethernet network ports for Grid and Client Networks
2
NIC 2 in the one-slot riser assembly
1/10-GbE Ethernet network ports for Admin Network
3
NIC 3 in the one-slot riser assembly
The SG1200 appliance supports higher speed network ports and might have higher speed NICs installed.
Step 1: Remove the NIC
Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
Locate the riser assembly that contains the NIC at the rear of the appliance.
Rotate the blue locking latch on the riser with the failed NIC up and open.
Carefully lift the riser assembly with the failed NIC upwards using the blue-marked holes. Move the riser assembly toward the front of the chassis as you lift it to allow the external connectors in its installed NIC to clear the chassis.
Place the riser on a flat anti-static surface with the metal frame side down to access the NIC.
Open the blue latch on the failed NIC and carefully remove it from the riser assembly. Rock the NIC slightly to help remove the NIC from its connector. Don't use excessive force.
Place the riser and NIC on a flat anti-static surface.
Rotate the blue lock on the riser with the failed NIC to the open position.
Carefully lift the riser assembly upwards using the blue-marked hole and riser edge. Move the riser assembly toward the front of the chassis as you lift it to allow the external connectors in its installed NIC to clear the chassis.
Step 2: Reinstall the internal NIC
Install the replacement NIC into the same location as the one that was removed.
Remove the replacement NIC from its packaging.
Install the replacement NIC into the riser assembly.
Ensure the blue latch is in the open position.
Align the NIC with its connector on the riser assembly. Carefully press the NIC into the connector until it is fully seated, and then close the blue latch.
Reinstall the riser assembly into chassis.
Locate the alignment hole on the riser assembly that aligns with a guide pin on the system board to ensure correct riser assembly positioning.
Position the riser assembly in the chassis, making sure that it aligns with the connector on the system board and guide pin.
Carefully press the riser assembly in place along its center line, next to the blue-marked holes, until it is fully seated.
If you have no other maintenance procedures to perform in the appliance, reinstall the appliance cover, return the appliance to the rack, attach cables, and apply power.
After replacing the part, return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Parts Return & Replacements page for further information.
Position the riser assembly in the chassis, making sure that the edges of the riser assembly correctly align with the edges of the chassis.
Carefully press the riser assembly in place along its center line, next to the blue-marked hole, until it is fully seated.
Rotate the blue lock on the riser to the closed position.
Remove the protective caps from the NIC ports where you will be reinstalling cables.
