Customize Trident operator deployment
The Trident operator provides enables you to customize the manner in which Astra Trident is installed by using the attributes in the TridentOrchestrator
spec.
See the following table for the list of attributes:
Parameter | Description | Default |
Namespace to install Astra Trident in |
"default" |
Enable debugging for Astra Trident |
false |
Install Astra Trident over IPv6 |
false |
Timeout for Kubernetes operations |
30sec |
Don’t send autosupport bundles to NetApp |
false |
Manage worker node dependencies automatically (BETA) |
false |
The container image for Autosupport Telemetry |
"netapp/trident-autosupport:21.04.0" |
The address/port of a proxy for sending Autosupport |
"http://proxy.example.com:8888" |
A flag used to uninstall Astra Trident |
false |
Astra Trident logging format to be used [text,json] |
"text" |
Astra Trident image to install |
"netapp/trident:21.04" |
Path to internal registry, of the format |
"k8s.gcr.io/sig-storage (k8s 1.17+) |
Path to the kubelet directory on the host |
“/var/lib/kubelet” |
A list of resources to delete to perform a complete removal of |
Secrets to pull images from an internal registry |
spec.namespace is specified in TridentOrchestrator to signify which namespace Astra Trident is installed in. This parameter cannot be updated after Astra Trident is installed. Attempting to do so causes the status of TridentOrchestrator to change to Failed . Astra Trident is not meant to be migrated across namespaces.
Automatic worker node prep is a beta feature meant to be used in non-production environments only. |
You can use the attributes mentioned above when defining TridentOrchestrator
to customize your installation. Here’s an example:
$ cat deploy/crds/tridentorchestrator_cr_imagepullsecrets.yaml apiVersion: trident.netapp.io/v1 kind: TridentOrchestrator metadata: name: trident spec: debug: true namespace: trident tridentImage: netapp/trident:21.04.0 imagePullSecrets: - thisisasecret
If you are looking to customize the installation beyond what TridentOrchestrator
arguments allow, you should consider using tridentctl
to generate custom YAML manifests that you can modify as needed.
