ONTAP SAN configuration options and examples
Learn how to create and use ONTAP SAN drivers with your Astra Trident installation. This section provides backend configuration examples and details for mapping backends to StorageClasses.
Backend configuration options
See the following table for the backend configuration options:
| Parameter | Description | Default |
Always 1 |
Name of the storage driver |
Custom name or the storage backend |
Driver name + "_" + dataLIF |
IP address of a cluster or SVM management LIF. |
“10.0.0.1”, “[2001:1234:abcd::fefe]” |
IP address of protocol LIF. |
Derived by the SVM |
Storage virtual machine to use |
Derived if an SVM |
Use CHAP to authenticate iSCSI for ONTAP SAN drivers [Boolean]. |
CHAP initiator secret. Required if |
Set of arbitrary JSON-formatted labels to apply on volumes |
CHAP target initiator secret. Required if |
Inbound username. Required if |
Target username. Required if |
Base64-encoded value of client certificate. Used for certificate-based auth |
Base64-encoded value of client private key. Used for certificate-based auth |
Base64-encoded value of trusted CA certificate. Optional. Used for certificate-based authentication. |
Username needed to communicate with the ONTAP cluster. Used for credential-based authentication. |
Password needed to communicate with the ONTAP cluster. Used for credential-based authentication. |
Derived if an SVM |
Prefix used when provisioning new volumes in the SVM. |
Fail provisioning if usage is above this percentage. |
"" (not enforced by default) |
Fail provisioning if requested volume size is above this value. |
Maximum LUNs per Flexvol, must be in range [50, 200] |
Debug flags to use when troubleshooting. Example, {"api":false, "method":true} |
Boolean parameter to use ONTAP REST APIs. Tech preview |
Backend configuration options for provisioning volumes
You can control default provisioning using these options in the defaults section of the configuration. For an example, see the configuration examples below.
Space-allocation for LUNs |
"true" |
Space reservation mode; "none" (thin) or "volume" (thick) |
"none" |
Snapshot policy to use |
"none" |
QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool/backend. |
Adaptive QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool/backend |
Percentage of volume reserved for snapshots |
"0" if |
Split a clone from its parent upon creation |
"false" |
Enable NetApp Volume Encryption (NVE) on the new volume; defaults to |
"false" |
Enable LUKS encryption. Refer to Use Linux Unified Key Setup (LUKS). |
Security style for new volumes |
Tiering policy to use "none" |
"snapshot-only" for pre-ONTAP 9.5 SVM-DR configuration |
Volume provisioning examples
Here's an example with defaults defined:
--- version: 1 storageDriverName: ontap-san managementLIF: 10.0.0.1 svm: trident_svm username: admin password: <password> labels: k8scluster: dev2 backend: dev2-sanbackend storagePrefix: alternate-trident debugTraceFlags: api: false method: true defaults: spaceReserve: volume qosPolicy: standard spaceAllocation: 'false' snapshotPolicy: default snapshotReserve: '10'
For all volumes created using the ontap-san driver, Astra Trident adds an extra 10 percent capacity to the FlexVol to accommodate the LUN metadata. The LUN will be provisioned with the exact size that the user requests in the PVC. Astra Trident adds 10 percent to the FlexVol (shows as Available size in ONTAP). Users will now get the amount of usable capacity they requested. This change also prevents LUNs from becoming read-only unless the available space is fully utilized. This does not apply to ontap-san-economy.
For backends that define snapshotReserve, Astra Trident calculates the size of volumes as follows:
Total volume size = [(PVC requested size) / (1 - (snapshotReserve percentage) / 100)] * 1.1
The 1.1 is the extra 10 percent Astra Trident adds to the FlexVol to accommodate the LUN metadata. For snapshotReserve = 5%, and PVC request = 5GiB, the total volume size is 5.79GiB and the available size is 5.5GiB. The volume show command should show results similar to this example:
Currently, resizing is the only way to use the new calculation for an existing volume.
Minimal configuration examples
The following examples show basic configurations that leave most parameters to default. This is the easiest way to define a backend.
If you are using Amazon FSx on NetApp ONTAP with Astra Trident, we recommend you specify DNS names for LIFs instead of IP addresses. |
ONTAP SAN example
This is a basic configuration using the ontap-san driver.
--- version: 1 storageDriverName: ontap-san managementLIF: 10.0.0.1 svm: svm_iscsi labels: k8scluster: test-cluster-1 backend: testcluster1-sanbackend username: vsadmin password: <password>
ONTAP SAN economy example
--- version: 1 storageDriverName: ontap-san-economy managementLIF: 10.0.0.1 svm: svm_iscsi_eco username: vsadmin password: <password>
MetroCluster example
You can configure the backend to avoid having to manually update the backend definition after switchover and switchback during SVM replication and recovery.
For seamless switchover and switchback, specify the SVM using managementLIF and omit the dataLIF and svm parameters. For example:
--- version: 1 storageDriverName: ontap-san managementLIF: 192.168.1.66 username: vsadmin password: password
Certificate-based authentication example
In this basic configuration example clientCertificate, clientPrivateKey, and trustedCACertificate (optional, if using trusted CA) are populated in backend.json and take the base64-encoded values of the client certificate, private key, and trusted CA certificate, respectively.
--- version: 1 storageDriverName: ontap-san backendName: DefaultSANBackend managementLIF: 10.0.0.1 svm: svm_iscsi useCHAP: true chapInitiatorSecret: cl9qxIm36DKyawxy chapTargetInitiatorSecret: rqxigXgkesIpwxyz chapTargetUsername: iJF4heBRT0TCwxyz chapUsername: uh2aNCLSd6cNwxyz clientCertificate: ZXR0ZXJwYXB...ICMgJ3BhcGVyc2 clientPrivateKey: vciwKIyAgZG...0cnksIGRlc2NyaX trustedCACertificate: zcyBbaG...b3Igb3duIGNsYXNz
Bidirectional CHAP examples
These examples create a backend with useCHAP set to true.
--- version: 1 storageDriverName: ontap-san managementLIF: 10.0.0.1 svm: svm_iscsi labels: k8scluster: test-cluster-1 backend: testcluster1-sanbackend useCHAP: true chapInitiatorSecret: cl9qxIm36DKyawxy chapTargetInitiatorSecret: rqxigXgkesIpwxyz chapTargetUsername: iJF4heBRT0TCwxyz chapUsername: uh2aNCLSd6cNwxyz username: vsadmin password: <password>
--- version: 1 storageDriverName: ontap-san-economy managementLIF: 10.0.0.1 svm: svm_iscsi_eco useCHAP: true chapInitiatorSecret: cl9qxIm36DKyawxy chapTargetInitiatorSecret: rqxigXgkesIpwxyz chapTargetUsername: iJF4heBRT0TCwxyz chapUsername: uh2aNCLSd6cNwxyz username: vsadmin password: <password>
Examples of backends with virtual pools
In these sample backend definition files, specific defaults are set for all storage pools, such as spaceReserve at none, spaceAllocation at false, and encryption at false. The virtual pools are defined in the storage section.
Astra Trident sets provisioning labels in the "Comments" field. Comments are set on the FlexVol. Astra Trident copies all labels present on a virtual pool to the storage volume at provisioning. For convenience, storage administrators can define labels per virtual pool and group volumes by label.
In these examples, some of the storage pools set their own spaceReserve, spaceAllocation, and encryption values, and some pools override the default values.
ONTAP SAN example
version: 1
svm: svm_iscsi
useCHAP: true
username: vsadmin
defaults:
encryption: 'false'
qosPolicy: standard
labels:
store: san_store
kubernetes-cluster: prod-cluster-1
region: us_east_1
storage:
- labels:
protection: gold
creditpoints: '40000'
zone: us_east_1a
defaults:
spaceAllocation: 'true'
encryption: 'true'
adaptiveQosPolicy: adaptive-extreme
- labels:
protection: silver
creditpoints: '20000'
zone: us_east_1b
defaults:
encryption: 'true'
qosPolicy: premium
- labels:
protection: bronze
creditpoints: '5000'
zone: us_east_1c
defaults:
encryption: 'false'
version: 1
svm: svm_iscsi_eco
useCHAP: true
username: vsadmin
defaults:
encryption: 'false'
labels:
store: san_economy_store
region: us_east_1
storage:
- labels:
app: oracledb
cost: '30'
zone: us_east_1a
defaults:
encryption: 'true'
- labels:
app: postgresdb
cost: '20'
zone: us_east_1b
defaults:
encryption: 'true'
- labels:
app: mysqldb
cost: '10'
zone: us_east_1c
defaults:
encryption: 'false'
- labels:
department: legal
zone: us_east_1c
defaults:
encryption: 'false'
Map backends to StorageClasses
The following StorageClass definitions refer to the Examples of backends with virtual pools. Using the parameters.selector field, each StorageClass calls out which virtual pools can be used to host a volume. The volume will have the aspects defined in the chosen virtual pool.
The
protection-goldStorageClass will map to the first virtual pool in theontap-sanbackend. This is the only pool offering gold-level protection.apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: protection-gold provisioner: netapp.io/trident parameters: selector: "protection=gold" fsType: "ext4"
The
protection-not-goldStorageClass will map to the second and third virtual pool inontap-sanbackend. These are the only pools offering a protection level other than gold.apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: protection-not-gold provisioner: netapp.io/trident parameters: selector: "protection!=gold" fsType: "ext4"
The
app-mysqldbStorageClass will map to the third virtual pool inontap-san-economybackend. This is the only pool offering storage pool configuration for the mysqldb type app.apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: app-mysqldb provisioner: netapp.io/trident parameters: selector: "app=mysqldb" fsType: "ext4"
The
protection-silver-creditpoints-20kStorageClass will map to the second virtual pool inontap-sanbackend. This is the only pool offering silver-level protection and 20000 creditpoints.apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: protection-silver-creditpoints-20k provisioner: netapp.io/trident parameters: selector: "protection=silver; creditpoints=20000" fsType: "ext4"
The
creditpoints-5kStorageClass will map to the third virtual pool inontap-sanbackend and the fourth virtual pool in theontap-san-economybackend. These are the only pool offerings with 5000 creditpoints.apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: creditpoints-5k provisioner: netapp.io/trident parameters: selector: "creditpoints=5000" fsType: "ext4"
Astra Trident will decide which virtual pool is selected and will ensure the storage requirement is met.
