ONTAP SAN configuration options and examples
Contributors netapp-aruldeepa
Learn how to create and use ONTAP SAN drivers with your Trident installation. This section provides backend configuration examples and details for mapping backends to StorageClasses.
Backend configuration options
See the following table for the backend configuration options:
Parameter Description Default
version
Always 1
storageDriverName
Name of the storage driver
ontap-san or ontap-san-economy
backendName
Custom name or the storage backend
Driver name + "_" + dataLIF
managementLIF
IP address of a cluster or SVM management LIF.
A fully-qualified domain name (FQDN) can be specified.
Can be set to use IPv6 addresses if Trident was installed using the IPv6 flag. IPv6 addresses must be defined in square brackets, such as [28e8:d9fb:a825:b7bf:69a8:d02f:9e7b:3555].
For seamless MetroCluster switchover, see the MetroCluster example.
Note If you are using "vsadmin" credentials, managementLIF must be that of the SVM; if using "admin" credentials, managementLIF must be that of the cluster.
"10.0.0.1", "[2001:1234:abcd::fefe]"
dataLIF
IP address of protocol LIF.
Do not specify for iSCSI. Trident uses ONTAP Selective LUN Map to discover the iSCSI LIFs needed to establish a multi path session. A warning is generated if dataLIF is explicitly defined.
Omit for Metrocluster. See the MetroCluster example.
Derived by the SVM
svm
Storage virtual machine to use
Derived if an SVM managementLIF is specified
useCHAP
Use CHAP to authenticate iSCSI for ONTAP SAN drivers [Boolean].
Set to true for Trident to configure and use bidirectional CHAP as the default authentication for the SVM given in the backend. Refer to Prepare to configure backend with ONTAP SAN drivers for details.
false
chapInitiatorSecret
CHAP initiator secret. Required if useCHAP=true
labels
Set of arbitrary JSON-formatted labels to apply on volumes
chapTargetInitiatorSecret
CHAP target initiator secret. Required if useCHAP=true
chapUsername
Inbound username. Required if useCHAP=true
chapTargetUsername
Target username. Required if useCHAP=true
clientCertificate
Base64-encoded value of client certificate. Used for certificate-based auth
clientPrivateKey
Base64-encoded value of client private key. Used for certificate-based auth
trustedCACertificate
Base64-encoded value of trusted CA certificate. Optional. Used for certificate-based authentication.
username
Username needed to communicate with the ONTAP cluster. Used for credential-based authentication.
password
Password needed to communicate with the ONTAP cluster. Used for credential-based authentication.
svm
storagePrefix
Prefix used when provisioning new volumes in the SVM.
Cannot be modified later. To update this parameter, you will need to create a new backend.
trident
aggregate
Aggregate for provisioning (optional; if set, must be assigned to the SVM). For the ontap-nas-flexgroup driver, this option is ignored. If not assigned, any of the available aggregates can be used to provision a FlexGroup volume.
Note When the aggregate is updated in SVM, it is updated in Trident automatically by polling SVM without having to restart the Trident Controller. When you have configured a specific aggregate in Trident to provision volumes, if the aggregate is renamed or moved out of the SVM, the backend will move to failed state in Trident while polling the SVM aggregate. You must either change the aggregate to one that is present on the SVM or remove it altogether to bring the backend back online.
Do not specify for ASA r2.
limitAggregateUsage
Fail provisioning if usage is above this percentage.
If you are using an Amazon FSx for NetApp ONTAP backend, do not specify limitAggregateUsage. The provided fsxadmin and vsadmin do not contain the permissions required to retrieve aggregate usage and limit it using Trident.
"" (not enforced by default)
limitVolumeSize
Fail provisioning if requested volume size is above this value.
Also restricts the maximum size of the volumes it manages for LUNs.
lunsPerFlexvol
Maximum LUNs per Flexvol, must be in range [50, 200]
100
debugTraceFlags
Debug flags to use when troubleshooting. Example, {"api":false, "method":true}
Do not use unless you are troubleshooting and require a detailed log dump.
null
useREST
Boolean parameter to use ONTAP REST APIs.
useREST When set to true, Trident uses ONTAP REST APIs to communicate with the backend; when set to false, Trident uses ONTAPI (ZAPI) calls to communicate with the backend. This feature requires ONTAP 9.11.1 and later. In addition, the ONTAP login role used must have access to the ontapi application. This is satisfied by the pre-defined vsadmin and cluster-admin roles. Beginning with the Trident 24.06 release and ONTAP 9.15.1 or later, useREST is set to true by default; change useREST to false to use ONTAPI (ZAPI) calls.
useREST is fully qualified for NVMe/TCP.
If specified, always set to true for ASA r2.
true for ONTAP 9.15.1 or later, otherwise false.
sanType
Use to select iscsi for iSCSI, nvme for NVMe/TCP or fcp for SCSI over Fibre Channel (FC).
iscsi if blank
formatOptions
Use formatOptions to specify command line arguments for the mkfs command, which will be applied whenever a volume is formatted. This allows you to format the volume according to your preferences. Make sure to specify the formatOptions similar to that of the mkfs command options, excluding the device path.
Example: "-E nodiscard"
Supported for ontap-san and ontap-san-economy drivers only.
limitVolumePoolSize
Maximum requestable FlexVol size when using LUNs in ontap-san-economy backend.
denyNewVolumePools
Restricts ontap-san-economy backends from creating new FlexVol volumes to contain their LUNs. Only preexisting Flexvols are used for provisioning new PVs.
Recommendations for using formatOptions
Trident recommends the following option to expedite the formatting process:
-E nodiscard:
  • Keep, do not attempt to discard blocks at mkfs time (discarding blocks initially is useful on solid state devices and sparse / thin-provisioned storage). This replaces the deprecated option "-K" and it is applicable to all the file systems (xfs, ext3, and ext4).
Backend configuration options for provisioning volumes
You can control default provisioning using these options in the defaults section of the configuration. For an example, see the configuration examples below.
spaceAllocation
Space-allocation for LUNs
"true"
If specified, set to true for ASA r2.
spaceReserve
Space reservation mode; "none" (thin) or "volume" (thick).
Set to none for ASA r2.
"none"
snapshotPolicy
Snapshot policy to use.
"none"
qosPolicy
QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool/backend.
Using QoS policy groups with Trident requires ONTAP 9.8 or later. You should use a non-shared QoS policy group and ensuring the policy group is applied to each constituent individually. A shared QoS policy group enforces the ceiling for the total throughput of all workloads.
adaptiveQosPolicy
Adaptive QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool/backend
snapshotReserve
Percentage of volume reserved for snapshots.
"0" if snapshotPolicy is "none", otherwise ""
splitOnClone
Split a clone from its parent upon creation
"false"
encryption
Enable NetApp Volume Encryption (NVE) on the new volume; defaults to false. NVE must be licensed and enabled on the cluster to use this option.
If NAE is enabled on the backend, any volume provisioned in Trident will be NAE enabled.
For more information, refer to: How Trident works with NVE and NAE.
"false"
luksEncryption
Enable LUKS encryption. Refer to Use Linux Unified Key Setup (LUKS).
Set to false for ASA r2.
tieringPolicy
Tiering policy to use "none"
nameTemplate
Template to create custom volume names.
Volume provisioning examples
Here's an example with defaults defined:
version: 1
storageDriverName: ontap-san
managementLIF: 10.0.0.1
svm: trident_svm
username: admin
password: <password>
labels:
  k8scluster: dev2
  backend: dev2-sanbackend
storagePrefix: alternate-trident
debugTraceFlags:
  api: false
  method: true
defaults:
  spaceReserve: volume
  qosPolicy: standard
  spaceAllocation: 'false'
  snapshotPolicy: default
  snapshotReserve: '10'
Note For all volumes created using the ontap-san driver, Trident adds an extra 10 percent capacity to the FlexVol to accommodate the LUN metadata. The LUN will be provisioned with the exact size that the user requests in the PVC. Trident adds 10 percent to the FlexVol (shows as Available size in ONTAP). Users will now get the amount of usable capacity they requested. This change also prevents LUNs from becoming read-only unless the available space is fully utilized. This does not apply to ontap-san-economy.
For backends that define snapshotReserve, Trident calculates the size of volumes as follows:
Total volume size = [(PVC requested size) / (1 - (snapshotReserve percentage) / 100)] * 1.1
The 1.1 is the extra 10 percent Trident adds to the FlexVol to accommodate the LUN metadata. For snapshotReserve = 5%, and PVC request = 5GiB, the total volume size is 5.79GiB and the available size is 5.5GiB. The volume show command should show results similar to this example:
Shows the output of the volume show command.
Currently, resizing is the only way to use the new calculation for an existing volume.
Minimal configuration examples
The following examples show basic configurations that leave most parameters to default. This is the easiest way to define a backend.
Note If you are using Amazon FSx on NetApp ONTAP with Trident, NetApp recommends that you specify DNS names for LIFs instead of IP addresses.
ONTAP SAN example
This is a basic configuration using the ontap-san driver.
version: 1
svm: svm_iscsi
labels:
  k8scluster: test-cluster-1
  backend: testcluster1-sanbackend
username: vsadmin
You can configure the backend to avoid having to manually update the backend definition after switchover and switchback during SVM replication and recovery.
For seamless switchover and switchback, specify the SVM using managementLIF and omit the svm parameters. For example:
version: 1
managementLIF: 192.168.1.66
username: vsadmin
password: password
ONTAP SAN economy example
version: 1
storageDriverName: ontap-san-economy
svm: svm_iscsi_eco
username: vsadmin
Certificate-based authentication example
In this basic configuration example clientCertificate, clientPrivateKey, and trustedCACertificate (optional, if using trusted CA) are populated in backend.json and take the base64-encoded values of the client certificate, private key, and trusted CA certificate, respectively.
version: 1
backendName: DefaultSANBackend
svm: svm_iscsi
useCHAP: true
chapInitiatorSecret: cl9qxIm36DKyawxy
chapTargetInitiatorSecret: rqxigXgkesIpwxyz
chapTargetUsername: iJF4heBRT0TCwxyz
chapUsername: uh2aNCLSd6cNwxyz
clientCertificate: ZXR0ZXJwYXB...ICMgJ3BhcGVyc2
clientPrivateKey: vciwKIyAgZG...0cnksIGRlc2NyaX
trustedCACertificate: zcyBbaG...b3Igb3duIGNsYXNz
Bidirectional CHAP examples
These examples create a backend with useCHAP set to true.
ONTAP SAN CHAP example
version: 1
svm: svm_iscsi
labels:
useCHAP: true
username: vsadmin
ONTAP SAN economy CHAP example
version: 1
svm: svm_iscsi_eco
useCHAP: true
username: vsadmin
NVMe/TCP example
You must have an SVM configured with NVMe on your ONTAP backend. This is a basic backend configuration for NVMe/TCP.
version: 1
backendName: NVMeBackend
svm: svm_nvme
username: vsadmin
password: password
sanType: nvme
useREST: true
SCSI over FC (FCP) example
You must have an SVM configured with FC on your ONTAP backend. This is a basic backend configuration for FC.
version: 1
backendName: fcp-backend
svm: svm_fc
username: vsadmin
password: password
sanType: fcp
useREST: true
Backend configuration example with nameTemplate
version: 1
backendName: ontap-san-backend
managementLIF: <ip address>
svm: svm0
username: <admin>
defaults:
  nameTemplate: "{{.volume.Name}}_{{.labels.cluster}}_{{.volume.Namespace}}_{{.vo\
    lume.RequestName}}"
labels:
  cluster: ClusterA
  PVC: "{{.volume.Namespace}}_{{.volume.RequestName}}"
formatOptions example for ontap-san-economy driver
version: 1
managementLIF: ""
svm: svm1
username: ""
password: "!"
storagePrefix: whelk_
debugTraceFlags:
  method: true
  api: true
defaults:
  formatOptions: -E nodiscard
Examples of backends with virtual pools
In these sample backend definition files, specific defaults are set for all storage pools, such as spaceReserve at none, spaceAllocation at false, and encryption at false. The virtual pools are defined in the storage section.
Trident sets provisioning labels in the "Comments" field. Comments are set on the FlexVol volume Trident copies all labels present on a virtual pool to the storage volume at provisioning. For convenience, storage administrators can define labels per virtual pool and group volumes by label.
In these examples, some of the storage pools set their own spaceReserve, spaceAllocation, and encryption values, and some pools override the default values.
ONTAP SAN example
version: 1
svm: svm_iscsi
useCHAP: true
username: vsadmin
defaults:
  spaceAllocation: "false"
  encryption: "false"
  qosPolicy: standard
labels:
  store: san_store
  kubernetes-cluster: prod-cluster-1
region: us_east_1
storage:
  - labels:
      protection: gold
      creditpoints: "40000"
    zone: us_east_1a
    defaults:
      spaceAllocation: "true"
      encryption: "true"
      adaptiveQosPolicy: adaptive-extreme
  - labels:
      protection: silver
      creditpoints: "20000"
    zone: us_east_1b
    defaults:
      encryption: "true"
      qosPolicy: premium
  - labels:
      protection: bronze
      creditpoints: "5000"
    zone: us_east_1c
    defaults:
      encryption: "false"
version: 1
svm: svm_iscsi_eco
useCHAP: true
username: vsadmin
defaults:
  encryption: "false"
labels:
  store: san_economy_store
region: us_east_1
storage:
  - labels:
      app: oracledb
      cost: "30"
    zone: us_east_1a
    defaults:
      encryption: "true"
  - labels:
      app: postgresdb
      cost: "20"
    zone: us_east_1b
    defaults:
      encryption: "true"
  - labels:
      app: mysqldb
      cost: "10"
    zone: us_east_1c
    defaults:
      encryption: "false"
  - labels:
      department: legal
    zone: us_east_1c
    defaults:
      encryption: "false"
NVMe/TCP example
version: 1
sanType: nvme
svm: nvme_svm
username: vsadmin
useREST: true
defaults:
  encryption: "true"
storage:
  - labels:
      app: testApp
      cost: "20"
    defaults:
      encryption: "false"
Map backends to StorageClasses
The following StorageClass definitions refer to the Examples of backends with virtual pools. Using the parameters.selector field, each StorageClass calls out which virtual pools can be used to host a volume. The volume will have the aspects defined in the chosen virtual pool.
  • The protection-gold StorageClass will map to the first virtual pool in the ontap-san backend. This is the only pool offering gold-level protection.
    apiVersion: storage.k8s.io/v1
    kind: StorageClass
    metadata:
    parameters:
      selector: "protection=gold"
      fsType: "ext4"
  • The protection-not-gold StorageClass will map to the second and third virtual pool in ontap-san backend. These are the only pools offering a protection level other than gold.
    kind: StorageClass
    metadata:
    parameters:
      selector: "protection!=gold"
      fsType: "ext4"
  • The app-mysqldb StorageClass will map to the third virtual pool in ontap-san-economy backend. This is the only pool offering storage pool configuration for the mysqldb type app.
    kind: StorageClass
    metadata:
    parameters:
      selector: "app=mysqldb"
      fsType: "ext4"
  • The protection-silver-creditpoints-20k StorageClass will map to the second virtual pool in ontap-san backend. This is the only pool offering silver-level protection and 20000 creditpoints.
    kind: StorageClass
    metadata:
    parameters:
      selector: "protection=silver; creditpoints=20000"
      fsType: "ext4"
  • The creditpoints-5k StorageClass will map to the third virtual pool in ontap-san backend and the fourth virtual pool in the ontap-san-economy backend. These are the only pool offerings with 5000 creditpoints.
    kind: StorageClass
    metadata:
    parameters:
      selector: "creditpoints=5000"
      fsType: "ext4"
  • The my-test-app-sc StorageClass will map to the testAPP virtual pool in the ontap-san driver with sanType: nvme. This is the only pool offering testApp.
    kind: StorageClass
    metadata:
    parameters:
      selector: "app=testApp"
      fsType: "ext4"
Trident will decide which virtual pool is selected and ensures the storage requirement is met.
