Upgrade a Trident installation using Trident operator or Helm
You can upgrade Trident using the Trident operator either manually or using Helm. You can upgrade from a Trident operator installation to another Trident operator installation or upgrade from a tridentctl installation to a Trident operator version. Review Select an upgrade method before upgrading a Trident operator installation.
Upgrade a manual installation
You can upgrade from a cluster-scoped Trident operator installation to another cluster-scoped Trident operator installation. All Trident versions 21.01 and above use a cluster-scoped operator.
To upgrade from Trident that was installed using the namespace-scoped operator (versions 20.07 through 20.10), use the upgrade instructions for your installed version of Trident. |
Trident provides a bundle file you can use to install the operator and create associated objects for your Kubernetes version.
For clusters running Kubernetes 1.25 or later, use bundle_post_1_25.yaml.
Ensure you are using a Kubernetes cluster running a supported Kubernetes version.
Verify your Trident version:
./tridentctl -n trident version
Delete the Trident operator that was used to install the current Trident instance. For example, if you are upgrading from 23.07, run the following command:
kubectl delete -f 23.07.0/trident-installer/deploy/<bundle.yaml> -n trident
If you customized your initial installation using
TridentOrchestratorattributes, you can edit theTridentOrchestratorobject to modify the installation parameters. This might include changes made to specify mirrored Trident and CSI image registries for offline mode, enable debug logs, or specify image pull secrets. -
Install Trident using the correct bundle YAML file for your environment, where <bundle.yaml> is
bundle_pre_1_25.yamlorbundle_post_1_25.yamlbased on your Kubernetes version. For example, if you are installing Trident 25.02, run the following command:kubectl create -f 25.02.0/trident-installer/deploy/<bundle.yaml> -n trident
Upgrade a Helm installation
You can upgrade a Trident Helm installation.
When upgrading a Kubernetes cluster from 1.24 to 1.25 or later that has Trident installed, you must update values.yaml to set excludePodSecurityPolicy to true or add --set excludePodSecurityPolicy=true to the helm upgrade command before you can upgrade the cluster.
If you have already upgraded your Kubernetes cluster from 1.24 to 1.25 without upgrading the Trident helm, the helm upgrade fails. For the helm upgrade to go through, perform these steps as pre-requisites:
Install the helm-mapkubeapis plugin from https://github.com/helm/helm-mapkubeapis.
Perform a dry run for the Trident release in the namespace where Trident is installed. This lists out the resources, which will be cleaned up.
helm mapkubeapis --dry-run trident --namespace trident
Perform a full run with helm to do the cleanup.
helm mapkubeapis trident --namespace trident
If you installed Trident using Helm, you can use
helm upgrade trident netapp-trident/trident-operator --version 100.2502.0to upgrade in one step. If you did not add the Helm repo or cannot use it to upgrade:-
Download the latest Trident release from the Assets section on GitHub.
Use the
helm upgradecommand wheretrident-operator-25.02.0.tgzreflects the version that you want to upgrade to.helm upgrade <name> trident-operator-25.02.0.tgz
If you set custom options during the initial installation (such as specifying private, mirrored registries for Trident and CSI images), append the helm upgradecommand using--setto ensure those options are included in the upgrade command, otherwise the values will reset to default.
Run
helm listto verify that the chart and app version have both been upgraded. Runtridentctl logsto review any debug messages.
Upgrade from a tridentctl installation to Trident operator
You can upgrade to the latest release of the Trident operator from a tridentctl installation. The existing backends and PVCs will automatically be available.
Before switching between installation methods, review Moving between installation methods. |
Download the latest Trident release.
# Download the release required [25.02.0] mkdir 25.02.0 cd 25.02.0 wget https://github.com/NetApp/trident/releases/download/v25.02.0/trident-installer-25.02.0.tar.gz tar -xf trident-installer-25.02.0.tar.gz cd trident-installer
Create the
tridentorchestratorCRD from the manifest.kubectl create -f deploy/crds/trident.netapp.io_tridentorchestrators_crd_post1.16.yaml
Deploy the cluster-scoped operator in the same namespace.
kubectl create -f deploy/<bundle-name.yaml> serviceaccount/trident-operator created clusterrole.rbac.authorization.k8s.io/trident-operator created clusterrolebinding.rbac.authorization.k8s.io/trident-operator created deployment.apps/trident-operator created podsecuritypolicy.policy/tridentoperatorpods created #Examine the pods in the Trident namespace NAME READY STATUS RESTARTS AGE trident-controller-79df798bdc-m79dc 6/6 Running 0 150d trident-node-linux-xrst8 2/2 Running 0 150d trident-operator-5574dbbc68-nthjv 1/1 Running 0 1m30s
Create a
TridentOrchestratorCR for installing Trident.cat deploy/crds/tridentorchestrator_cr.yaml apiVersion: trident.netapp.io/v1 kind: TridentOrchestrator metadata: name: trident spec: debug: true namespace: trident kubectl create -f deploy/crds/tridentorchestrator_cr.yaml #Examine the pods in the Trident namespace NAME READY STATUS RESTARTS AGE trident-csi-79df798bdc-m79dc 6/6 Running 0 1m trident-csi-xrst8 2/2 Running 0 1m trident-operator-5574dbbc68-nthjv 1/1 Running 0 5m41s
Confirm Trident was upgraded to the intended version.
kubectl describe torc trident | grep Message -A 3 Message: Trident installed Namespace: trident Status: Installed Version: v25.02.0
