Uninstall Trident
You should use the same method to uninstall Trident that you used to install Trident.
About this task
  • If you need a fix for bugs observed after an upgrade, dependency issues, or an unsuccessful or incomplete upgrade, you should uninstall Trident and reinstall the earlier version using the specific instructions for that version. This is the only recommended way to downgrade to an earlier version.
  • For easy upgrade and reinstallation, uninstalling Trident does not remove the CRDs or related objects created by Trident. If you need to completely remove Trident and all of its data, refer to Completely remove Trident and CRDs.
Before you begin
If you are decommissioning Kubernetes clusters, you must delete all applications that use volumes created by Trident prior to uninstalling. This ensures that PVCs are unpublished on Kubernetes nodes before they are deleted.
Determine the original installation method
You should use the same method to uninstall Trident that you used to install it. Before uninstalling, verify which version you used to originally install Trident.
  1. Use kubectl get pods -n trident to examine the pods.
    • If there is no operator pod, Trident was installed using tridentctl.
    • If there is an operator pod, Trident was installed using the Trident operator either manually or using Helm.
  2. If there is an operator pod, use kubectl describe tproc trident to determine if Trident was installed using Helm.
    • If there is a Helm label, Trident was installed using Helm.
    • If there is no Helm label, Trident was installed manually using the Trident operator.
Uninstall a Trident operator installation
You can uninstall a trident operator installation manually or using Helm.
Uninstall manual installation
If you installed Trident using the operator, you can uninstall it by doing one of the following:
  1. Edit TridentOrchestrator CR and set the uninstall flag:
    kubectl patch torc <trident-orchestrator-name> --type=merge -p '{"spec":{"uninstall":true}}'
    When the uninstall flag is set to true, the Trident operator uninstalls Trident, but does not remove the TridentOrchestrator itself. You should clean up the TridentOrchestrator and create a new one if you want to install Trident again.
  2. Delete TridentOrchestrator: By removing the TridentOrchestrator CR that was used to deploy Trident, you instruct the operator to uninstall Trident. The operator processes the removal of TridentOrchestrator and proceeds to remove the Trident deployment and daemonset, deleting the Trident pods it had created as part of the installation.
    kubectl delete -f deploy/<bundle.yaml> -n <namespace>
Uninstall Helm installation
If you installed Trident by using Helm, you can uninstall it by using helm uninstall.
#List the Helm release corresponding to the Trident install.
helm ls -n trident
NAME          NAMESPACE       REVISION        UPDATED                                 STATUS          CHART                           APP VERSION
trident       trident         1               2021-04-20 00:26:42.417764794 +0000 UTC deployed        trident-operator-21.07.1        21.07.1
#Uninstall Helm release to remove Trident
helm uninstall trident -n trident
release "trident" uninstalled
Uninstall a tridentctl installation
Use the uninstall command in tridentctl to remove all of the resources associated with Trident except for the CRDs and related objects:
./tridentctl uninstall -n <namespace>
