Google Cloud NetApp Volumes backend configuration options and examples
Learn about backend configuration options for Google Cloud NetApp Volumes and review configuration examples.
Backend configuration options
Each backend provisions volumes in a single Google Cloud region. To create volumes in other regions, you can define additional backends.
Parameter Description Default
version
Always 1
storageDriverName
Name of the storage driver
The value of storageDriverName must be specified as "google-cloud-netapp-volumes".
backendName
(Optional) Custom name of the storage backend
Driver name + "_" + part of API key
storagePools
Optional parameter used to specify storage pools for volume creation.
projectNumber
Google Cloud account project number. The value is found on the Google Cloud portal home page.
location
The Google Cloud location where Trident creates GCNV volumes. When creating cross-region Kubernetes clusters, volumes created in a location can be used in workloads scheduled on nodes across multiple Google Cloud regions.
Cross-region traffic incurs an additional cost.
apiKey
API key for the Google Cloud service account with the netapp.admin role.
It includes the JSON-formatted contents of a Google Cloud service account's private key file (copied verbatim into the backend configuration file).
The apiKey must include key-value pairs for the following keys: type, project_id, client_email, client_id, auth_uri, token_uri, auth_provider_x509_cert_url, and client_x509_cert_url.
nfsMountOptions
Fine-grained control of NFS mount options.
"nfsvers=3"
limitVolumeSize
Fail provisioning if the requested volume size is above this value.
"" (not enforced by default)
serviceLevel
The service level of a storage pool and its volumes.
The values are flex, standard, premium, or extreme.
labels
Set of arbitrary JSON-formatted labels to apply on volumes
network
Google Cloud network used for GCNV volumes.
debugTraceFlags
Debug flags to use when troubleshooting. Example, {"api":false, "method":true}.
Do not use this unless you are troubleshooting and require a detailed log dump.
null
nasType
Configure NFS or SMB volumes creation.
Options are nfs, smb or null. Setting to null defaults to NFS volumes.
nfs
supportedTopologies
Represents a list of regions and zones that are supported by this backend.
For more information, refer to Use CSI Topology.
For example:
supportedTopologies:
- topology.kubernetes.io/region: asia-east1
topology.kubernetes.io/zone: asia-east1-a
Volume provisioning options
You can control default volume provisioning in the defaults section of the configuration file.
exportRule
The export rules for new volumes. Must be a comma-separated list of any combination of IPv4 addresses.
"0.0.0.0/0"
snapshotDir
Access to the .snapshot directory
"true" for NFSv4
"false" for NFSv3
snapshotReserve
Percentage of volume reserved for snapshots
"" (accept default of 0)
unixPermissions
The unix permissions of new volumes (4 octal digits).
Example configurations
The following examples show basic configurations that leave most parameters to default. This is the easiest way to define a backend.
Minimal configuration
This is the absolute minimum backend configuration. With this configuration, Trident discovers all of your storage pools delegated to Google Cloud NetApp Volumes in the configured location, and places new volumes on one of those pools randomly. Because nasType is omitted, the nfs default applies and the backend will provision for NFS volumes.
This configuration is ideal when you are just getting started with Google Cloud NetApp Volumes and trying things out, but in practice you will most likely need to provide additional scoping for the volumes you provision.
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
  private_key_id: f2cb6ed6d7cc10c453f7d3406fc700c5df0ab9ec
  private_key: |
    -----BEGIN PRIVATE KEY-----
    znHczZsrrtHisIsAbOguSaPIKeyAZNchRAGzlzZE4jK3bl/qp8B4Kws8zX5ojY9m
    XsYg6gyxy4zq7OlwWgLwGa==
    -----END PRIVATE KEY-----
kind: TridentBackendConfig
metadata:
spec:
  version: 1
  storageDriverName: google-cloud-netapp-volumes
  projectNumber: "123455380079"
  serviceLevel: premium
  apiKey:
    type: service_account
    project_id: my-gcnv-project
    client_email: myproject-prod@my-gcnv-project.iam.gserviceaccount.com
    client_id: "103346282737811234567"
    auth_uri: https://accounts.google.com/o/oauth2/auth
    token_uri: https://oauth2.googleapis.com/token
    auth_provider_x509_cert_url: https://www.googleapis.com/oauth2/v1/certs
    client_x509_cert_url: https://www.googleapis.com/robot/v1/metadata/x509/myproject-prod%40my-gcnv-project.iam.gserviceaccount.com
  credentials:
Configuration for SMB volumes
metadata:
  namespace: trident
spec:
  version: 1
  projectNumber: "123456789"
  serviceLevel: flex
  nasType: smb
  apiKey:
    project_id: cloud-native-data
    client_email: trident-sample@cloud-native-data.iam.gserviceaccount.com
    client_id: "123456789737813416734"
    client_x509_cert_url: https://www.googleapis.com/robot/v1/metadata/x509/trident-sample%40cloud-native-data.iam.gserviceaccount.com
  credentials:
Configuration with StoragePools filter
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
  private_key: |
metadata:
spec:
  version: 1
  storagePools:
    - premium-pool1-europe-west6
    - premium-pool2-europe-west6
  apiKey:
  credentials:
Virtual pool configuration
This backend configuration defines multiple virtual pools in a single file. Virtual pools are defined in the storage section. They are useful when you have multiple storage pools supporting different service levels and you want to create storage classes in Kubernetes that represent those. Virtual pool labels are used to differentiate the pools. For instance, in the example below performance label and serviceLevel type is used to differentiate virtual pools.
You can also set some default values to be applicable to all virtual pools, and overwrite the default values for individual virtual pools. In the following example, snapshotReserve and exportRule serve as defaults for all virtual pools.
For more information, refer to Virtual pools.
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
  private_key: |
metadata:
spec:
  version: 1
  apiKey:
  credentials:
  defaults:
    snapshotReserve: "10"
    exportRule: 10.0.0.0/24
  storage:
    - labels:
        performance: extreme
      serviceLevel: extreme
      defaults:
        snapshotReserve: "5"
        exportRule: 0.0.0.0/0
    - labels:
        performance: premium
    - labels:
        performance: standard
      serviceLevel: standard
Cloud identity for GKE
metadata:
spec:
  version: 1
  projectNumber: '012345678901'
  network: gcnv-network
  serviceLevel: Premium
  storagePool: pool-premium1
Supported topologies configuration
Trident facilitates provisioning of volumes for workloads based on regions and availability zones. The supportedTopologies block in this backend configuration is used to provide a list of regions and zones per backend. The region and zone values specified here must match the region and zone values from the labels on each Kubernetes cluster node. These regions and zones represent the list of permissible values that can be provided in a storage class. For storage classes that contain a subset of the regions and zones provided in a backend, Trident creates volumes in the mentioned region and zone.
version: 1
subscriptionID: 9f87c765-4774-fake-ae98-a721add45451
tenantID: 68e4f836-edc1-fake-bff9-b2d865ee56cf
clientID: dd043f63-bf8e-fake-8076-8de91e5713aa
clientSecret: SECRET
serviceLevel: flex
    topology.kubernetes.io/zone: asia-east1-b
What's next?
After you create the backend configuration file, run the following command:
kubectl create -f <backend-file>
To verify that the backend is successfully created, run the following command:
kubectl get tridentbackendconfig
NAME               BACKEND NAME       BACKEND UUID                           PHASE   STATUS
backend-tbc-gcnv   backend-tbc-gcnv   b2fd1ff9-b234-477e-88fd-713913294f65   Bound   Success
If the backend creation fails, something is wrong with the backend configuration. You can describe the backend using the kubectl get tridentbackendconfig <backend-name> command or view the logs to determine the cause by running the following command:
tridentctl logs
After you identify and correct the problem with the configuration file, you can delete the backend and run the create command again.
Storage class definitions
The following is a basic StorageClass definition that refers to the backend above.
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
  backendType: "google-cloud-netapp-volumes"
Example definitions using the parameter.selector field:
Using parameter.selector you can specify for each StorageClass the virtual pool that is used to host a volume. The volume will have the aspects defined in the chosen pool.
kind: StorageClass
metadata:
parameters:
  selector: performance=extreme
  backendType: google-cloud-netapp-volumes
kind: StorageClass
metadata:
parameters:
  selector: performance=premium
kind: StorageClass
metadata:
parameters:
  selector: performance=standard
For more details on storage classes, refer to Create a storage class.
Example definitions for SMB volumes
Using nasType, node-stage-secret-name, and node-stage-secret-namespace, you can specify an SMB volume and provide the required Active Directory credentials. Any Active Directory user/password with any/no permissions can be used for the node stage secret.
Basic configuration on default namespace
kind: StorageClass
metadata:
parameters:
  trident.netapp.io/nasType: "smb"
  csi.storage.k8s.io/node-stage-secret-name: "smbcreds"
  csi.storage.k8s.io/node-stage-secret-namespace: "default"
Using different secrets per namespace
kind: StorageClass
metadata:
parameters:
  csi.storage.k8s.io/node-stage-secret-namespace: ${pvc.namespace}
Using different secrets per volume
kind: StorageClass
metadata:
parameters:
  csi.storage.k8s.io/node-stage-secret-name: ${pvc.name}
Note nasType: smb filters for pools which support SMB volumes. nasType: nfs or nasType: null filters for NFS pools.
PVC definition example
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 100Gi
  storageClassName: gcnv-nfs-sc
To verify if the PVC is bound, run the following command:
kubectl get pvc gcnv-nfs-pvc
NAME          STATUS   VOLUME                                    CAPACITY  ACCESS MODES   STORAGECLASS AGE
gcnv-nfs-pvc  Bound    pvc-b00f2414-e229-40e6-9b16-ee03eb79a213  100Gi     RWX            gcnv-nfs-sc  1m
