Restore applications using Trident Protect
You can use Trident Protect to restore your application from a snapshot or backup. Restoring from an existing snapshot will be faster when restoring the application to the same cluster.
Note
  • When you restore an application, all execution hooks configured for the application are restored with the app. If a post-restore execution hook is present, it runs automatically as part of the restore operation.
  • Restoring from a backup to a different namespace or to the original namespace is supported for qtree volumes. However, restoring from a snapshot to a different namespace or to the original namespace is not supported for qtree volumes.
  • You can use advanced settings to customize restore operations. To learn more, refer to Use advanced Trident Protect restore settings.
Restore from a backup to a different namespace
When you restore a backup to a different namespace using a BackupRestore CR, Trident Protect restores the application in a new namespace and creates an application CR for the restored application. To protect the restored application, create on-demand backups or snapshots, or establish a protection schedule.
Note
  • Restoring a backup to a different namespace with existing resources will not alter any resources that share names with those in the backup. To restore all resources in the backup, either delete and re-create the target namespace, or restore the backup to a new namespace.
  • When using a CR to restore to a new namespace, you must manually create the destination namespace before applying the CR. Trident Protect automatically creates namespaces only when using the CLI.
Before you begin
Ensure that the AWS session token expiration is sufficient for any long-running s3 restore operations. If the token expires during the restore operation, the operation can fail.
Note When you restore backups using Kopia as the data mover, you can optionally specify annotations in the CR or using the CLI to control the behavior of the temporary storage used by Kopia. Refer to the Kopia documentation for more information about the options you can configure. Use the tridentctl-protect create --help command for more information about specifying annotations with the Trident Protect CLI.
Use a CR
Steps
  1. Create the custom resource (CR) file and name it trident-protect-backup-restore-cr.yaml.
  2. In the file you created, configure the following attributes:
    • metadata.name: (Required) The name of this custom resource; choose a unique and sensible name for your environment.
    • spec.appArchivePath: The path inside AppVault where the backup contents are stored. You can use the following command to find this path:
      kubectl get backups <BACKUP_NAME> -n my-app-namespace -o jsonpath='{.status.appArchivePath}'
    • spec.appVaultRef: (Required) The name of the AppVault where the backup contents are stored.
    • spec.destinationApplicationName: (Optional) The name for the restored application. If provided, the restored application uses this name. If not provided, the restored application uses the source application name.
    • spec.namespaceMapping: The mapping of the source namespace of the restore operation to the destination namespace. Replace my-source-namespace and my-destination-namespace with information from your environment.
      apiVersion: protect.trident.netapp.io/v1
      kind: BackupRestore
      metadata:
        namespace: my-destination-namespace
      spec:
        appArchivePath: my-backup-path
        appVaultRef: appvault-name
        destinationApplicationName: my-new-app-name
        namespaceMapping: [{"source": "my-source-namespace", "destination": "my-destination-namespace"}]
  3. (Optional) If you need to select only certain resources of the application to restore, add filtering that includes or excludes resources marked with particular labels:
    Note Trident Protect selects some resources automatically because of their relationship with resources that you select. For example, if you select a persistent volume claim resource and it has an associated pod, Trident Protect will also restore the associated pod.
    • resourceFilter.resourceSelectionCriteria: (Required for filtering) Use Include or Exclude to include or exclude a resource defined in resourceMatchers. Add the following resourceMatchers parameters to define the resources to be included or excluded:
      • resourceFilter.resourceMatchers: An array of resourceMatcher objects. If you define multiple elements in this array, they match as an OR operation, and the fields inside each element (group, kind, version) match as an AND operation.
        • resourceMatchers[].group: (Optional) Group of the resource to be filtered.
        • resourceMatchers[].kind: (Optional) Kind of the resource to be filtered.
        • resourceMatchers[].version: (Optional) Version of the resource to be filtered.
        • resourceMatchers[].names: (Optional) Names in the Kubernetes metadata.name field of the resource to be filtered.
        • resourceMatchers[].namespaces: (Optional) Namespaces in the Kubernetes metadata.name field of the resource to be filtered.
        • resourceMatchers[].labelSelectors: (Optional) Label selector string in the Kubernetes metadata.name field of the resource as defined in the Kubernetes documentation. For example: "trident.netapp.io/os=linux".
          For example:
          spec:
            resourceFilter:
              resourceSelectionCriteria: "Include"
              resourceMatchers:
                - group: my-resource-group-1
                  kind: my-resource-kind-1
                  version: my-resource-version-1
                  names: ["my-resource-names"]
                  namespaces: ["my-resource-namespaces"]
                  labelSelectors: ["trident.netapp.io/os=linux"]
                - group: my-resource-group-2
                  kind: my-resource-kind-2
                  version: my-resource-version-2
  4. After you populate the trident-protect-backup-restore-cr.yaml file with the correct values, apply the CR:
    kubectl apply -f trident-protect-backup-restore-cr.yaml
Use the CLI
Steps
  1. Restore the backup to a different namespace, replacing values in brackets with information from your environment. The namespace-mapping argument uses colon-separated namespaces to map source namespaces to the correct destination namespaces in the format source1:dest1,source2:dest2. For example:
    tridentctl-protect create backuprestore <my_restore_name> \
    --backup <backup_namespace>/<backup_to_restore> \
    --namespace-mapping <source_to_destination_namespace_mapping> \ --destination-app-name<custom_app_name>\
    -n <application_namespace>
Restore from a backup to the original namespace
You can restore a backup to the original namespace at any time. When you perform an in-place restore, Trident Protect automatically manages protection schedules and in-progress operations to prevent invalid recovery points:
  • All enabled protection schedules for the application are disabled before the restore begins. This prevents scheduled backups or snapshots from running while the application resources are being restored.
  • After the restore completes successfully, only the schedules that were enabled before the restore are re-enabled. Schedules that were already disabled remain disabled.
  • Any in-progress backup or snapshot operations are cancelled before the restore begins. If an operation does not cancel within 5 minutes, the restore proceeds and logs a warning in the restore CR status.
Before you begin
Use a CR
Steps
  1. Create the custom resource (CR) file and name it trident-protect-backup-ipr-cr.yaml.
      For example:
      kind: BackupInplaceRestore
      metadata:
        namespace: my-app-namespace
      spec:
          For example:
          spec:
            resourceFilter:
              resourceMatchers:
  4. After you populate the trident-protect-backup-ipr-cr.yaml file with the correct values, apply the CR:
    kubectl apply -f trident-protect-backup-ipr-cr.yaml
Use the CLI
Steps
  1. Restore the backup to the original namespace, replacing values in brackets with information from your environment. The backup argument uses a namespace and backup name in the format <namespace>/<name>. For example:
    tridentctl-protect create backupinplacerestore <my_restore_name> \
    --backup <namespace/backup_to_restore> \
Restore from a backup to a different cluster
You can restore a backup to a different cluster if there is an issue with the original cluster.
Note
  • When you restore backups using Kopia as the data mover, you can optionally specify annotations in the CR or using the CLI to control the behavior of the temporary storage used by Kopia. Refer to the Kopia documentation for more information about the options you can configure. Use the tridentctl-protect create --help command for more information about specifying annotations with the Trident Protect CLI.
Before you begin
Ensure the following prerequisites are met:
  • The destination cluster has Trident Protect installed.
  • The destination cluster has access to the bucket path of the same AppVault as the source cluster, where the backup is stored.
  • Ensure that your local environment can connect to the object storage bucket defined in the AppVault CR when running the tridentctl-protect get appvaultcontent command. If network restrictions prevent access, run the Trident Protect CLI from within a pod on the destination cluster instead.
  • Ensure that the AWS session token expiration is sufficient for any long-running restore operations. If the token expires during the restore operation, the operation can fail.
    • Refer to the AWS API documentation for more information about checking the current session token expiration.
    • Refer to the AWS documentation for more information about credentials with AWS resources.
Steps
  1. Verify that the AppVault CR exists on the destination cluster using the Trident Protect CLI plugin:
    tridentctl-protect get appvault --context <destination_cluster_name>
    Note If the AppVault CR does not exist on the destination cluster, create it by following the steps in Use Trident Protect AppVault objects to manage buckets.
  2. View the backup contents of the available AppVault on the destination cluster, and note appArchivePath of the backup you want to restore:
    tridentctl-protect get appvaultcontent <appvault_name> \
    --show-resources backup \
    --show-paths \
    Running this command displays the available backups in the AppVault, including their originating clusters, corresponding application names, timestamps, and archive paths.
    Example output:
    |   CLUSTER   |    APP    |  TYPE  |      NAME       |        TIMESTAMP         |    PATH     |
    | production1 | wordpress | backup | wordpress-bkup-1| 2024-10-30 08:37:40 (UTC)| backuppath1 |
    | production1 | wordpress | backup | wordpress-bkup-2| 2024-10-30 08:37:40 (UTC)| backuppath2 |
  3. Restore the application to the destination cluster using the AppVault name and archive path:
Note When using a CR, ensure that the namespace intended for the application restore exists on the destination cluster.
Use a CR
    • spec.appArchivePath: (Required) The path inside AppVault where the backup contents are stored. Use the command from step 2 to view the backup contents and find appArchivePath for the backup you want to restore.
      For example:
      kind: BackupRestore
      metadata:
      spec:
  3. After you populate the trident-protect-backup-restore-cr.yaml file with the correct values, apply the CR:
Use the CLI
  1. Use the following command to restore the application, replacing values in brackets with information from your environment. The namespace-mapping argument uses colon-separated namespaces to map source namespaces to the correct destination namespaces in the format source1:dest1,source2:dest2. For example:
    tridentctl-protect create backuprestore <restore_name> \
    --appvault <appvault_name> \
    --path <backup_path> \
    --destination-app-name <custom_app_name> \
    --context <destination_cluster_name> \
Restore from a snapshot to a different namespace
You can restore data from a snapshot using a custom resource (CR) file either to a different namespace or the original source namespace. When you restore a snapshot to a different namespace using a SnapshotRestore CR, Trident Protect restores the application in a new namespace and creates an application CR for the restored application. To protect the restored application, create on-demand backups or snapshots, or establish a protection schedule.
Note
  • SnapshotRestore supports the spec.storageClassMapping attribute, but only when the source and destination storage classes use the same storage backend. If you attempt to restore to a StorageClass that uses a different storage backend, the restore operation will fail.
Before you begin
Use a CR
Steps
  1. Create the custom resource (CR) file and name it trident-protect-snapshot-restore-cr.yaml.
    • spec.appVaultRef: (Required) The name of the AppVault where the snapshot contents are stored.
    • spec.appArchivePath: The path inside AppVault where the snapshot contents are stored. You can use the following command to find this path:
      kubectl get snapshots <SNAPHOT_NAME> -n my-app-namespace -o jsonpath='{.status.appArchivePath}'
      kind: SnapshotRestore
      metadata:
      spec:
        appArchivePath: my-snapshot-path
          For example:
          spec:
            resourceFilter:
              resourceMatchers:
  4. After you populate the trident-protect-snapshot-restore-cr.yaml file with the correct values, apply the CR:
    kubectl apply -f trident-protect-snapshot-restore-cr.yaml
Use the CLI
Steps
  1. Restore the snapshot to a different namespace, replacing values in brackets with information from your environment.
    • The snapshot argument uses a namespace and snapshot name in the format <namespace>/<name>.
    • The namespace-mapping argument uses colon-separated namespaces to map source namespaces to the correct destination namespaces in the format source1:dest1,source2:dest2.
      For example:
      tridentctl-protect create snapshotrestore <my_restore_name> \
      --snapshot <namespace/snapshot_to_restore> \
Restore from a snapshot to the original namespace
You can restore a snapshot to the original namespace at any time. When you perform an in-place restore, Trident Protect automatically manages protection schedules and in-progress operations to prevent invalid recovery points:
Before you begin
Use a CR
Steps
  1. Create the custom resource (CR) file and name it trident-protect-snapshot-ipr-cr.yaml.
      kubectl get snapshots <SNAPSHOT_NAME> -n my-app-namespace -o jsonpath='{.status.appArchivePath}'
      kind: SnapshotInplaceRestore
      metadata:
      spec:
          For example:
          spec:
            resourceFilter:
              resourceMatchers:
  4. After you populate the trident-protect-snapshot-ipr-cr.yaml file with the correct values, apply the CR:
    kubectl apply -f trident-protect-snapshot-ipr-cr.yaml
Use the CLI
Steps
  1. Restore the snapshot to the original namespace, replacing values in brackets with information from your environment. For example:
    tridentctl-protect create snapshotinplacerestore <my_restore_name> \
Check the status of a restore operation
You can use the command line to check the status of a restore operation that is in progress, has completed, or has failed.
Steps
  1. Use the following command to retrieve status of the restore operation, replacing values in brackes with information from your environment:
    kubectl get backuprestore -n <namespace_name> <my_restore_cr_name> -o jsonpath='{.status}'
