Encrypt AppVault metadata for Trident Protect snapshots and backups
Contributors netapp-shwetav
You can encrypt the snapshot and backup metadata that Trident Protect stores in an AppVault, including sensitive information in Kubernetes Secrets. You can also change the password that protects the encrypted data. A single password change re-encrypts the metadata encryption key and moves every Kopia repository and every Restic repository in the AppVault to the new password.
Encryption is disabled by default. When you enable it, Trident Protect encrypts new snapshot and backup metadata before it stores the metadata in the AppVault. This protects your application resources, including sensitive information in Secrets, unless you explicitly exclude those resources from the application snapshot or backup.
A vault password protects the key that encrypts the data. Note the following behavior:
  • When you change the vault password, Trident Protect protects the same key with the new password. It does not rewrite data that is already encrypted.
  • Data that was stored before you enabled encryption remains readable.
  • Data that was encrypted remains readable, even if you later turn off encryption for new data.
About this task
When you enable encryption, Trident Protect uses an insecure default password unless you specify a custom password. For each AppVault, create a custom vault password and reference it in spec.vaultPasswordSecretRef.
If you enabled encryption with the default password and add a custom password later, you must rotate the password so that existing data and repositories move to the custom password. Refer to Rotate the vault password.
Use a unique custom password for each AppVault. Rotate the password for one AppVault at a time, and confirm that the rotation is complete before you start another password change.
Before you begin
Ensure that you have the following:
  • Access to the trident-protect namespace.
  • Permission to create Kubernetes Secrets and patch AppVault custom resources (CRs).
  • A separate password Secret planned for each AppVault.
Enable metadata encryption
You enable metadata encryption by setting a Helm value for Trident Protect.
Steps
  1. Set resourceBackupEncryptionEnabled to true by using a values.yaml file:
    1. Add the following to your values.yaml file:
      resourceBackupEncryptionEnabled: true
    2. Apply the file:
      helm upgrade trident-protect -n trident-protect netapp-trident-protect/trident-protect -f values.yaml --reuse-values
  2. Alternatively, set resourceBackupEncryptionEnabled to true by using the Helm --set flag:
    helm upgrade trident-protect -n trident-protect netapp-trident-protect/trident-protect \
      --set resourceBackupEncryptionEnabled=true \
      --reuse-values
Result
Trident Protect encrypts new snapshot and backup metadata.
What's next?
Create a custom vault password for each AppVault. Until you do, Trident Protect uses the insecure default password.
To use your own password, create a Kubernetes Secret that contains the password, and then reference the Secret in the AppVault.
About this task
If you configure the custom password when you create the AppVault, before any data is stored, the AppVault uses the custom password immediately. You do not need to rotate the password.
If the AppVault already has Kopia or Restic repositories, adding a new password does not change the password of those repositories. Do not use the steps in this section. Instead, follow the steps in Rotate the vault password.
The VAULT_PASSWORD value must meet the following requirements:
  • Must not be empty
  • Must be shorter than 64 KiB
  • Must not contain a NUL character
  • Must not contain a line break
  • Must not start or end with a space or other blank character
The password can contain other characters, including non-ASCII characters.
Steps
  1. Create a Secret in the same namespace as the AppVault. The Secret must contain a key named VAULT_PASSWORD:
    kubectl -n trident-protect create secret generic vault-password \
      --from-literal=VAULT_PASSWORD='<password>'
    Note If the AppVault reports that the password is not valid, check the VAULT_PASSWORD value against the requirements above. Common causes are an empty value, a trailing line feed, or spaces at the start or end of the password.
  2. Reference the Secret in the spec.vaultPasswordSecretRef field of the AppVault CR:
    apiVersion: protect.trident.netapp.io/v1
    kind: AppVault
    metadata:
      namespace: trident-protect
    spec:
      vaultPasswordSecretRef: vault-password
      providerType: <provider-type>
      providerConfig:
        <provider-configuration>
    If spec.vaultPasswordSecretRef is empty, the AppVault uses the insecure default password.
Result
The AppVault uses your custom password to protect the metadata encryption key.
You can rotate the password for an AppVault that already stores data. One rotation re-encrypts the metadata encryption key and moves every Kopia repository and every Restic repository in the AppVault to the new password.
About this task
During rotation, Trident Protect does the following:
  • Waits for running backup and restore jobs for the AppVault to finish before it starts.
  • Protects the metadata encryption key (metadata-key.json) with the new password. It does not rewrite the archive objects.
  • Finds each Kopia repository and each Restic repository under the AppVault prefix, and changes its password to the new password. Repositories that already open with the new password are not changed.
  • Skips repositories that a backup or restore job is still using, and retries them later.
  • Suspends the enabled schedules that reference the AppVault. For each schedule, Trident Protect sets spec.enabled to false and adds the following annotation:
    protect.trident.netapp.io/vault-password-rotation-suspended: <namespace>/<appvault-name>
When rotation finishes, Trident Protect enables again only the schedules that have this annotation.
If a rotation fails, it resumes from where it stopped. Repositories that already use the new password are not changed again.
Before you begin
Steps
  1. Create a new Secret with a name that is different from the name of the current Secret:
    kubectl -n trident-protect create secret generic vault-password-new \
      --from-literal=VAULT_PASSWORD='<new-password>'
    Important Do not edit or delete the current Secret before rotation finishes. Trident Protect needs the current password to open existing data until every repository uses the new password. If you delete the current Secret too early, re-create it with the same name and the original VAULT_PASSWORD value.
  2. Enable rotation and set the AppVault to use the new Secret. Replace my-vault with the name of your AppVault:
    kubectl -n trident-protect patch appvault my-vault --type merge --patch '
    spec:
      enableRotation: true
      vaultPasswordSecretRef: vault-password-new
    Note You must set spec.enableRotation to true before you change the password. If it is false, the AppVault reports that rotation is disabled and does not change the password.
  3. Monitor the rotation by following the steps in Monitor password rotation.
  4. After rotation finishes, delete the previous Secret if nothing else uses it.
Result
The metadata encryption key and every Kopia and Restic repository in the AppVault are protected by the new password, and the schedules that Trident Protect suspended are enabled again.
You can check the progress of a password rotation and confirm that it is complete.
Steps
  1. View the AppVault:
    kubectl -n trident-protect get appvault my-vault --output yaml
  2. In the output, check the status.vaultPasswordRotation section. While rotation is in progress, it looks like this:
    status:
      vaultPasswordRotation:
        state: Rotating
        rotated: 3
        pending: 1
        message: <message>
    This table describes the fields:
    Field Description
    status.vaultPasswordRotation.state
    Current rotation state.
    status.vaultPasswordRotation.rotated
    Number of repositories that now use the new password.
    status.vaultPasswordRotation.pending
    Number of repositories that were skipped because a backup or restore is using them.
    status.vaultPasswordRotation.message
    Latest progress or failure message.
Result
Rotation is complete when all of the following are true:
  • status.vaultPasswordRotation is not present.
  • status.previousRepositoryPasswordSecretRef is empty.
  • status.repositoryPasswordSecretRef matches spec.vaultPasswordSecretRef.
What's next?
If rotation does not finish, check the following:
  • Rotation does not start: spec.enableRotation might be false. Set it to true, and then set spec.vaultPasswordSecretRef to the new Secret.
  • Repositories stay pending: Backup or restore jobs are still using them. Wait for the jobs to finish. Trident Protect retries the pending repositories automatically.
  • Rotation does not start because another AppVault owns the lock: Refer to Manage rotation for AppVaults that share a bucket.
  • The message field reports a failure: Resolve the problem that the message describes. Rotation resumes from where it stopped.
Migrate from dataMoverPasswordSecretRef
If an existing AppVault uses the older spec.dataMoverPasswordSecretRef field, you can move it to spec.vaultPasswordSecretRef.
About this task
Trident Protect keeps spec.dataMoverPasswordSecretRef for backward compatibility. Use spec.vaultPasswordSecretRef for new AppVaults.
Steps
  1. Keep spec.dataMoverPasswordSecretRef and its Secret in place.
  2. Rotate the password to a new Secret by using spec.vaultPasswordSecretRef. Follow the steps in Rotate the vault password.
  3. After rotation finishes, remove spec.dataMoverPasswordSecretRef from the AppVault.
  4. Delete the old Secret if nothing else uses it.
If several AppVaults use the same bucket and prefix, only one of them can rotate the password.
About this task
Password rotation uses a lock file named password-rotation.lock. The lock records the UID of the AppVault that is allowed to rotate the password for the bucket and prefix. If a second AppVault has spec.enableRotation: true and the lock names a different AppVault, the second AppVault cannot rotate.
Example 1. Steps
Transfer rotation to another AppVault
  1. On the AppVault that owns the lock, clear spec.enableRotation:
    kubectl -n trident-protect patch appvault <current-owner> --type merge --patch '
    spec:
      enableRotation: false
  2. Wait for the lock to be removed.
  3. On the AppVault that should rotate next, set spec.enableRotation to true:
    kubectl -n trident-protect patch appvault <new-owner> --type merge --patch '
    spec:
Remove a lock left by a deleted AppVault
Use these steps if the AppVault that owns the lock no longer exists and the lock was not removed, for example after a crash.
  1. Delete the password-rotation.lock file from the AppVault prefix in your bucket.
  2. On the AppVault that should rotate, set spec.enableRotation to true:
    kubectl -n trident-protect patch appvault <appvault-name> --type merge --patch '
    spec:
