Protect KubeVirt virtual machines with Trident Protect
Contributors netapp-shwetav
Trident Protect enables you to back up and restore KubeVirt virtual machines (VMs) running on OpenShift Virtualization. You can protect all VMs across one or more namespaces at once, or use the includedVirtualMachines field to target specific VMs by name. Trident Protect automatically collects all dependent VM resources during backup, and during restore, you can recover the entire archive or selectively restore individual VMs.
KubeVirt protection modes
Trident Protect supports two ways to define which KubeVirt VMs to protect. Choose one mode when you define an application:
Mode Field Description
Namespace-based
includedNamespaces
Protect all matching resources in one or more namespaces. Use a labelSelector on the namespace entry to control which VMs are included dynamically.
VM-scoped
Protect specific KubeVirt VMs by namespace and name. Use this mode when VMs are spread across namespaces or when you do not want to protect all namespace resources.
You must specify exactly one field (includedNamespaces or includedVirtualMachines) in the ApplicationSpec. You cannot use both in the same application.
Both modes support additional filtering:
  • Use resourceFilter to include or exclude specific resources.
  • Use includedClusterScopedResources to include compatible cluster-scoped resources, such as StorageClass objects.
Note
Resources collected during backup and snapshot
When you create a backup or snapshot for an application that includes KubeVirt VMs, Trident Protect collects the selected VM resources and automatically discovers their dependent resources.
The collection behavior applies in two cases:
  • VM-scoped applications that use includedVirtualMachines.
  • Namespace-based applications that contain KubeVirt VirtualMachine resources.
VM-scoped collection
For VM-scoped applications, Trident Protect starts with each VirtualMachine listed in includedVirtualMachines and discovers the dependent resources needed to restore that VM.
Resource type Scope How it is discovered
VirtualMachine
Namespaced
Direct match from the includedVirtualMachines list.
VirtualMachineInstance
Namespaced
Same namespace and name as the VM, if the VM is running.
VirtualMachineInstancetype
Namespaced
Referenced by spec.instancetype when kind: VirtualMachineInstancetype.
VirtualMachineClusterInstancetype
Cluster
Referenced by spec.instancetype when kind is unset or kind: VirtualMachineClusterInstancetype.
VirtualMachinePreference
Namespaced
Referenced by spec.preference when kind: VirtualMachinePreference.
VirtualMachineClusterPreference
Cluster
Referenced by spec.preference when kind is unset or kind: VirtualMachineClusterPreference.
DataVolume
Namespaced
Referenced by spec.template.spec.volumes[].dataVolume.name.
PersistentVolumeClaim
Namespaced
Discovered from DataVolume-backing PVCs, which use the same name as the DataVolume; direct PVC references in persistentVolumeClaim.claimName; memory dump PVCs in memoryDump.claimName; and ephemeral PVCs in ephemeral.persistentVolumeClaim.claimName.
PersistentVolume
Cluster
Discovered from the backing PV for each collected PVC by using spec.volumeName.
Secret
Namespaced
Discovered from volume secrets in secret.secretName; containerDisk image pull secrets; CloudInitNoCloud and CloudInitConfigDrive user-data and network-data secret references; Sysprep secrets; KernelBoot container image pull secrets; and AccessCredentials SSH or password secrets.
ConfigMap
Namespaced
Discovered from volume ConfigMaps in configMap.name and Sysprep ConfigMaps.
ServiceAccount
Namespaced
Discovered from serviceAccount.serviceAccountName volume references.
NetworkAttachmentDefinition
Namespaced
Discovered from Multus networks in spec.template.spec.networks[].multus.networkName when the network name does not contain /. Only same-namespace NetworkAttachmentDefinition references are collected. Cross-namespace references are skipped.
Pod
Namespaced
Discovered for virt-launcher Pods by using the label selector kubevirt.io=virt-launcher,vm.kubevirt.io/name=<vmName>.
Storage class, Trident volumes, and Trident backends
Cluster
Collected the same way as namespace-based applications, based on the PVCs discovered for the VM.
Note After all VM-scoped namespaced resources are collected, Trident Protect applies the standard resourceFilter, if one is configured. Cluster-scoped resource collection then proceeds as normal.
Namespace-based collection
For namespace-based applications, Trident Protect scans the selected namespaces and collects all matching resources. If any KubeVirt VirtualMachine objects are found, Trident Protect automatically collects their dependent resources, including instance types, preferences, and virt-launcher Pods, the same way it does for VM-scoped applications.
This means VM-specific resources are included in your backup or snapshot even when the application is defined with includedNamespaces.
Protect VMs using namespace-based application definitions
When you create a namespace-based application, Trident Protect scans the selected namespaces and collects all resources, including any KubeVirt VMs. For each virtual machine found, Trident Protect also collects the dependent resources needed to back up and restore that VM.
Example namespace-based application CR:
apiVersion: protect.trident.netapp.io/v1
kind: Application
metadata:
  namespace: <application_namespace>
spec:
  includedNamespaces:
    - namespace: <vm_namespace>
After you create the application, use the standard Trident Protect workflows for backups and snapshots:
Restore behavior for namespace-based VM applications
Because namespace-based applications collect resources from the selected namespaces, the backup or snapshot can include KubeVirt runtime objects and KubeVirt-managed metadata. Some of these objects should not be restored directly because they represent runtime state from the source cluster.
During restore, Trident Protect applies KubeVirt-aware transforms to remove source-cluster metadata and skip transient KubeVirt resources. This helps KubeVirt recreate the VM cleanly in the restored environment.
Resource Transform
VirtualMachine
Removes labels and annotations that start with kubevirt.io/.
VirtualMachineInstanceMigration
Ignored and not restored.
VirtualMachineSnapshot
VirtualMachineSnapshotContent
Pod (virt-launcher)
Skipped when the pod has the kubevirt.io=virt-launcher label.
Note
  • Trident Protect restores KubeVirt resources in a defined order to avoid dependency issues. CDI DataVolumes (cdi.kubevirt.io) are restored first so VM disk data is available before the VM objects are created. After that, VirtualMachines (kubevirt.io) are restored before VirtualMachineInstances.
  • By default, Trident Protect removes the MAC address from the first network interface of each restored VM. To retain it, use the protect.trident.netapp.io/retain-mac-address annotation. Refer to Use advanced Trident Protect restore settings.
Dynamic VM protection with label selectors
If you want to protect VMs dynamically without listing each VM name, use namespace-based application definitions with label selectors.
Only the VirtualMachine CR needs labels. Dependent resources such as DataVolumes, PVCs, Secrets, and ConfigMaps are collected automatically.
Steps
  1. Label virtual machine CRs with a shared label:
    kubectl label virtualmachine <vm_name 1> app=<label_value> -n <vm_namespace>
    kubectl label virtualmachine <vm_name_2> app=<label_value> -n <vm_namespace>
  2. Create an application CR with includedNamespaces and a labelSelector:
    kind: Application
    metadata:
    spec:
      includedNamespaces:
          labelSelector:
            matchLabels:
              app: <label_value>
  3. Create backups and restores using the standard Trident Protect workflow.
Additional details:
  • You can add or remove VMs from protection at any time by changing labels:
kubectl label virtualmachine <vm_name_to_add> app=<label_value> -n <vm_namespace>
kubectl label virtualmachine <vm_name_to_remove> app=<different_label_value> -n <vm_namespace>
  • You can also use label selectors across multiple namespaces:
spec:
  includedNamespaces:
    - namespace: <vm_namespace_1>
      labelSelector:
        matchLabels:
          <label_key>: <label_value>
    - namespace: <vm_namespace_2>
      labelSelector:
        matchLabels:
Protect specific VMs with includedVirtualMachines
Use includedVirtualMachines when you want to protect a named set of VirtualMachines across one or more namespaces and selectively restore specific VMs from an archive.
Both the application and restore CRs use the same includedVirtualMachines selector format.
Use this selector in different contexts:
  • In an application CR, it defines which VMs are protected.
  • In a restore CR, it defines which VMs are restored from the backup or snapshot archive.
Note On restore CRs, includedVirtualMachines is optional. If you do not include this field, the entire archive is restored. When specified, only the listed VMs and their dependent resources are restored.
The YAML below shows the shared selector structure:
includedVirtualMachines:
    names:
      - <vm_name_1>
      - <vm_name_2>
    names:
      - <vm_name_3>
Note Multiple entries in includedVirtualMachines can reference different namespaces, which enables multi-namespace VM-aware application definitions and restores.
Table 1. includedVirtualMachines selector fields
Field Type Description
namespace
string
Kubernetes namespace that contains the target virtual machine objects.
names
list of strings
One or more virtual machine names in that namespace.
Example VM-based application:
kind: Application
metadata:
spec:
      names:
        - <vm_name_1>
        - <vm_name_2>
      names:
        - <vm_name_3>
  includedClusterScopedResources:
    - group: storage.k8s.io
      kind: StorageClass
Restore specific KubeVirt VMs
You can use includedVirtualMachines on restore CRs to restore only selected KubeVirt VMs from a backup, snapshot, or replicated snapshot archive.
When includedVirtualMachines is specified on a restore CR, Trident Protect restores only the listed VirtualMachines and their dependent resources, such as VirtualMachineInstance, DataVolume, PersistentVolumeClaim, PersistentVolume, Secret, ConfigMap, ServiceAccount, and other VM-related objects.
If you do not specify includedVirtualMachines on the restore CR, Trident Protect restores the full archive according to the restore CR configuration.
Supported restore CRs and CLI commands
The following table lists the restore CRs that support includedVirtualMachines and their corresponding CLI commands.
Restore CR CLI command Description
BackupRestore
tridentctl-protect create backuprestore
Restores from a backup to new or different namespace mappings. Supports namespaceMapping and storageClassMapping.
BackupInplaceRestore
tridentctl-protect create backupinplacerestore
Restores from a backup into the original namespace or namespaces.
SnapshotRestore
tridentctl-protect create snapshotrestore
Restores from a snapshot to new or different namespace mappings. Supports namespaceMapping and storageClassMapping.
SnapshotInplaceRestore
tridentctl-protect create snapshotinplacerestore
Restores from a snapshot into the original namespace or namespaces.
ReplicateSnapshotRestore
YAML only, or use the supported CLI command if available in your environment
Restores from a replicated snapshot. Supports namespaceMapping, storageClassMapping, and in-place restore by using the inPlaceRestore flag.
Note The tridentctl-protect CLI does not have a flag for includedVirtualMachines on restore commands. To restore specific VMs, you must apply a restore CR YAML file directly using kubectl apply. You can write the YAML from scratch, or use the CLI with --dry-run --output yaml to generate a starting file, add the includedVirtualMachines field under spec, and then apply it.
VM-scoped restore behavior
The includedVirtualMachines field on a restore CR uses the same selector format as the application CR:
  - namespace: <source_vm_namespace>
    names:
      - <vm_name_1>
      - <vm_name_2>
For restore CRs, the namespace values in includedVirtualMachines refer to the source namespaces as they exist in the backup, snapshot, or replicated snapshot archive.
If you use namespaceMapping, Trident Protect first selects the requested VMs from the source archive and then applies namespace mappings during restore. If you use storageClassMapping, Trident Protect applies the storage class mappings during the restore transform phase.
Generate restore YAML with the CLI
You can use tridentctl-protect to generate a base restore CR and then edit the YAML to add includedVirtualMachines.
tridentctl-protect create <restore_command> <restore_name> \
  <restore_options> \
  --dry-run --output yaml > <restore_name>.yaml
Edit the generated YAML and add the includedVirtualMachines field under spec, then apply the file:
kubectl apply -f <restore_name>.yaml
Example: Define a VM-based application
The following application protects three specific VMs across two namespaces.
kind: Application
metadata:
  namespace: prod
spec:
    - namespace: prod
      names:
        - app-server
        - database-server
    - namespace: monitoring
      names:
        - prometheus-vm
      kind: StorageClass
Example: Create a backup
Creating a backup for a VM-based application uses the standard backup CR. No VM-specific fields are required on the backup CR.
kind: Backup
metadata:
  namespace: prod
spec:
  applicationRef: production-vms
  appVaultRef: s3-vault
Example: Restore a single VM from a backup
The following example restores only database-server from the backup archive. The other VMs in the archive, such as app-server and prometheus-vm, are skipped.
kind: BackupRestore
metadata:
  namespace: prod-vms-restore
spec:
  appArchivePath: backups/production-vms/2026-03-10T00-00-00Z
  namespaceMapping:
    - source: prod
      destination: prod-dr
    - namespace: prod
      names:
        - database-server
kubectl apply -f restore-db-only.yaml
Only database-server and its dependent resources, such as DataVolumes, PVCs, PVs, Secrets, ConfigMaps, and related KubeVirt resources, are restored.
Example: Restore a single VM in place from a backup
The following example restores only database-server into its original namespace from the backup archive.
kind: BackupInplaceRestore
metadata:
  namespace: prod
spec:
    - namespace: prod
      names:
        - database-server
kubectl apply -f ipr-db-only.yaml
Example: Restore a single VM from a snapshot
The following example restores only ubuntu-vm-blue-a627be38 from a snapshot archive.
kind: SnapshotRestore
metadata:
  namespace: blue
spec:
  appVaultRef: my-appvault
  appArchivePath: snapshots/protectctl-blue-vm/snap-1
    - namespace: blue
      names:
        - ubuntu-vm-blue-a627be38
kubectl apply -f blue-vm-snap-restore.yaml
Combine VM restore with other filters
You can use includedVirtualMachines together with resourceFilter, namespaceMapping, and storageClassMapping in the same restore CR to fine-tune what gets restored.
When you add a resourceFilter, Trident Protect first selects the VMs listed in includedVirtualMachines and their dependent resources. It then applies the resource filter to further narrow down what is included or excluded from those results.
spec:
      names:
        - <vm_name>
  resourceFilter:
    resourceSelectionCriteria: Include
    resourceMatchers:
      - kinds: ["PersistentVolumeClaim"]
        names: ["<pvc_name>"]
For BackupRestore, SnapshotRestore, and ReplicateSnapshotRestore, namespaceMapping and storageClassMapping work alongside includedVirtualMachines. Namespace references in includedVirtualMachines correspond to source namespaces as they appear in the archive. Namespace and storage class mappings are applied during the restore transform phase after filtering is complete.
For restore behavior details, refer to Restore applications using Trident Protect.
Create a VM-scoped application using the CLI
Use the --virtual-machines flag to scope an application to specific KubeVirt VMs instead of whole namespaces. The --virtual-machines flag is mutually exclusive with --namespaces.
Steps
  1. Create the application by running one of the following commands, replacing values in brackets with information from your environment. The format for the --virtual-machines flag is <namespace>(<vm_name>). For multiple VMs, use comma-separated names within the parentheses:
    • Single VM in a namespace:
      tridentctl-protect create application <application_name> \
        -n <application_namespace> \
        --virtual-machines "<vm_namespace>(<vm_name>)"
    • Multiple VMs across namespaces:
        --virtual-machines "<vm_namespace_1>(<vm_name_1>,<vm_name_2>),<vm_namespace_2>(<vm_name_3>)"
