Quick start for Builders
Contributors netapp-mwallis
Get started creating a Builders project. Administrators and team leads can use Builders to administer projects and workspaces for teams of developers.
One Log in to Workload Factory
You'll need to set up an account with Workload Factory and log in using one of the console experiences.
Two Add credentials and permissions
Choose the permission policies to meet your needs.
If you choose not to grant permissions, you can start using Workload Factory for Builders to copy partially completed code samples.
If you choose to grant permissions, you'll need to add credentials to an account manually that includes selecting workload capabilities, such as Builders and AI, and creating the IAM policies for the required permissions.
Three Set up your environment to meet Builders requirements
You'll need a deployed and discovered FSx for ONTAP file system that contains at least one volume that has been configured as an NFS share.
Four Integrate with other services
Integrate Builders with other services such as a service portal or Perforce Helix Core using the workload Factory REST API.
What's next
You can now create a project to provide fast and efficient management of code and artifacts to teams of developers.
