Learn about Perforce integration in Workload Factory for EDA
Contributors netapp-sineadd
Integrating Perforce with CI/CD pipelines enhances the development process by automating builds, tests, and deployments, leading to faster and more reliable software delivery.
Continuous Integration and Continuous Deployment (CI/CD) in EDA is a rapid build environment creation tool for software builders. It enables fast setup of personal development environments, saving time and enabling self-service for developers while empowering DevOps teams to retain control of the infrastructure. Using CI/CD, software developers can quickly create workspaces without needing specialized data storage or understanding of the development infrastructure.
What is CI/CD?
By using CI/CD, you can streamline the way developers manage and interact with different versions of their software. It works with Perforce Helix Core to instantly clone software versions and create workspaces for development, QA, and CI/CD.
You can easily create a project and assign a volume that represents your software environment and its artifacts. As you update your software, you can take snapshots of the volume, capturing the state of your software at that moment. You can access any software version instantly without resyncing, saving time and resources.
Using the snapshot and clone capabilities of NetApp ONTAP, you can quickly access different versions of your software, so you can develop and release updates faster. For more information about Workload Factory, refer to the Workload Factory overview.
CI/CD features
  • Create, edit, and remove projects. See Manage projects.
  • Create snapshots of defined software versions. See Manage project versions.
  • Create, and delete workspaces (based on clones). See Create a workspace.
  • Create access policies to control access to a project.
  • Analyze the capacity usage of each project.
  • Control clone size limits and clone retention for each project.
  • Integrate with version control systems such as Perforce. See Integrate with Perforce.
Projects and workspaces in EDA
You can create a project and assign a volume that represents your software environment and its artifacts. Each time that you create a new version of the software, you need resync the volume data and create a project snapshot to mark the volume state as a known version. The project source volume might get rolling updates and have multiple snapshots to mark multiple versions. You can use each snapshot immediately as an instant clone, a dedicated or shared editable repository available to developers, QA or build processes. A clone in the context of a specific software version is a workspace.
Automation with Workload Factory Codebox
Workload Factory introduces built-in automation with the Codebox. The Codebox offers the following automation benefits:
  • Code snippet generation: Infrastructure-as-Code (IaC) snippets are generated during resource creation, enabling seamless integration with existing orchestration workflows.
  • Infrastructure-as-code co-pilot: the Codebox is an Infrastructure-as-code (IaC) co-pilot that helps developers and DevOps generate code to execute any operation supported by Workload Factory.
  • Code viewer and automation catalog: the Codebox provides a code viewer for quick analysis of automation and an automation catalog for quick future re-use.
Cost
There is no cost for using the CI/CD capability of Workload Factory.
Licensing
No special licenses are needed from NetApp to use the CI/CD capabilities of Workload Factory.
Regions
EDA is supported in all commercial regions where FSx for ONTAP is supported. View supported Amazon regions.
The following AWS regions aren't supported:
  • China regions
  • Secret Cloud
  • Top Secret Cloud
Getting help
Amazon FSx for NetApp ONTAP is an AWS first-party solution. For support, use the Support Center in your AWS Management Console to open a case. Select "FSx for ONTAP" and the category, then provide the required information.
For general questions about Workload Factory or Workload Factory applications and services, refer to Get help for EDA for Workload Factory.
