所需的最低 vCenter 权限
在开始部署适用于 VMware vSphere 的 SnapCenter 插件之前,您应确保具有所需的最低 vCenter 特权。
vCenter 管理员角色所需的特权
数据存储库.AllocateSpace
数据存储库。浏览
数据存储库。删除
数据存储库。文件管理
数据存储库。mMove
数据存储库。重命名
扩展。注册
扩展。注销
extension.Update
Host.Config.AdvancedConfig
host.Config.Resources
Host.Config.Settings
host.Config.Storage
host.local.CreateVM
host.local.DeleteVM
host.local.ReconfigVM
网络。分配
资源。应用程序建议
资源。分配VMToPoool
资源。CLDMigrate
资源。热迁移
Resource.QuerVMotion
System.匿名
系统。读取
system.view
任务。创建
任务。更新
VirtualMachine.Config.AddExistingDisk
VirtualMachine.Config.AddNewDisk
VirtualMachine.Config.AdvancedConfig
VirtualMachine.Config.ReloadFromPath
VirtualMachine.Config.RemoveDisk
VirtualMachine.Config.Resource
VirtualMachine.GuestOperations.Execute
VirtualMachine.GuestOperations.Modify
VirtualMachine.GuestOperations.Query
VirtualMachine.interact。poweroff
VirtualMachine.inter互动.PowerOn
VirtualMachine.Inventory.Create
VirtualMachine.Inventory.CreateFromExisting
VirtualMachine.Inventory.Delete
VirtualMachine.Inventory.Move
VirtualMachine.Inventory.Register
VirtualMachine.Inventory.Unregign
VirtualMachine.State.CreateSnapshot
VirtualMachine.State.RemoveSnapshot
VirtualMachine.State.Re版本ToSnapshot
适用于 VMware vCenter 的 SnapCenter 插件所需的特权
* 权限 * |
标签 |
netappSCC.Guest.RestoreFile |
子系统文件还原 |
netappSCC.Recovery.MountUnMount |
挂载/卸载 |
netappSCC.Backup.DeleteBackupJob |
删除资源组/备份 |
netappSCC.Configure.ConfigureStorageSystems.Delete |
删除存储系统 |
netappSCV视图 |
查看 |
netappSCC.Recover.RecoverVM |
恢复VM |
netappSCC.Configure.ConfigureStorageSystems.AddUpdate |
添加/修改存储系统 |
netappSCC.Backup.BackupNow |
立即备份 |
netappSCC.Guest.Configure |
子系统配置 |
netappSCC.Configure.ConfigureSnapCenterServer |
配置SnapCenter 服务器 |
netappSCC.Backup.BackupScheduleed |
创建资源组 |
