SCV 所需的最低 vCenter 权限
在开始部署适用于 VMware vSphere 的 SnapCenter 插件之前,您应确保具有所需的最低 vCenter 特权。
vCenter 管理员角色所需的特权
数据存储库.AllocateSpace数据存储库。浏览数据存储库.Delete数据存储库.FileManagement数据存储库.Move数据存储库.重 命名扩展.Register扩展.Unregistrate扩展.Update Host.Config.AdvancedConfig Host.Config.Settings Host.Config.Storage Host.Local.CreateVM Host.Local.DeleteVM Host.Local.RecomedVirtual Machine Network.VirtualMachine.VirtualDisk.Unigrate.Unigrate.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Resety.VirtualMachine.Unigrate.VirtualMachine.Res.Res.Resete.Disk.Res.Res.VirtualMachine.Disk.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Disk.Res.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Un
适用于 VMware vCenter 的 SnapCenter 插件所需的特权
* 权限 * |
标签 |
netappSCC.Guest.RestoreFile |
子系统文件还原 |
netappSCC.Recovery.MountUnMount |
挂载/卸载 |
netappSCC.Backup.DeleteBackupJob |
删除资源组/备份 |
netappSCC.Configure.ConfigureStorageSystems.Delete |
删除存储系统 |
netappSCV视图 |
查看 |
netappSCC.Recover.RecoverVM |
恢复VM |
netappSCC.Configure.ConfigureStorageSystems.AddUpdate |
添加/修改存储系统 |
netappSCC.Backup.BackupNow |
立即备份 |
netappSCC.Guest.Configure |
子系统配置 |
netappSCC.Configure.ConfigureSnapCenterServer |
配置SnapCenter 服务器 |
netappSCC.Backup.BackupScheduleed |
创建资源组 |
