本产品推出了新版本。
所需的最低 vCenter 权限
在开始部署适用于 VMware vSphere 的 SnapCenter 插件之前,您应确保具有所需的最低 vCenter 特权。
vCenter 管理员角色所需的特权
数据存储库.AllocateSpace数据存储库。浏览数据存储库.Delete数据存储库.FileManagement数据存储库.Move数据存储库.重 命名扩展.Register扩展.Unregistrate扩展.Update Host.Config.AdvancedConfig Host.Config.Settings Host.Config.Storage Host.Local.CreateVM Host.Local.DeleteVM Host.Local.RecomedVirtual Machine Network.VirtualMachine.VirtualDisk.Unigrate.Unigrate.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Resety.VirtualMachine.Unigrate.VirtualMachine.Res.Res.Resete.Disk.Res.Res.VirtualMachine.Disk.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Disk.Res.VirtualMachine.Unigrate.VirtualMachine.Unigrate.VirtualMachine.Un
适用于 VMware vCenter 的 SnapCenter 插件所需的特权
* 权限 *
标签
netappSCC.Guest.RestoreFile
子系统文件还原
netappSCC.Recovery.MountUnMount
挂载/卸载
netappSCC.Backup.DeleteBackupJob
删除资源组/备份
netappSCC.Configure.ConfigureStorageSystems.Delete
删除存储系统
netappSCV视图
查看
netappSCC.Recover.RecoverVM
恢复虚拟机
netappSCC.Configure.ConfigureStorageSystems.AddUpdate
添加/修改存储系统
netappSCC.Backup.BackupNow
立即备份
netappSCC.Guest.Configure
子系统配置
netappSCC.Configure.ConfigureSnapCenterServer
配置SnapCenter服务器
netappSCC.Backup.BackupScheduleed
创建资源组
