Frequently asked questions for BlueXP ransomware protection
This FAQ can help if you're just looking for a quick answer to a question.
Access
What's the BlueXP ransomware protection URL?
For the URL, in a browser, enter: https://console.bluexp.netapp.com/ to access the BlueXP console.
Do you need a license to use BlueXP ransomware protection?
A NetApp License File (NLF) is not required. The BlueXP ransomware protection preview itself does not require any special licensing. All preview licenses are Evaluation licenses.
The preview version of this service requires a BlueXP backup and recovery service license.
For the preview version, NetApp helps to set up the evaluation and any required licenses. |
How do you enable BlueXP ransomware protection?
BlueXP ransomware protection does not require any enablement. The ransomware protection option is automatically enabled on the BlueXP left navigation.
For the preview version, you need to sign up or reach out to your NetApp Sales rep to try out this service. Then, when you use the BlueXP Connector, it will include the appropriate capabilities for the service.
Does BlueXP ransomware protection available in standard, restricted, and private modes?
At this time, BlueXP ransomware protection is available only in standard mode. Stay tuned for more.
For an explanation about these modes across all BlueXP services, refer to BlueXP deployment modes.
How are access permissions handled?
Only account admins have the ability to initiate the service and discover workloads (because this involves committing to usage of a resource). Subsequent interactions can be done by any role.
What device resolution is best?
The recommended device resolution for BlueXP ransomware protection is 1920x1080 or better.
Which browser should I use?
Any modern browser will work.
Interaction with other services
Is BlueXP ransomware protection aware of protection settings made in NetApp ONTAP?
Yes, BlueXP ransomware protection discovers Snapshot schedules set in ONTAP.
If you set a policy using BlueXP ransomware protection, do you have to make future changes only in this service?
We recommend that you make policy changes from the BlueXP ransomware protection service.
Workloads
What makes up a workload?
A workload includes all volumes that are used by a single application instance. For example, an Oracle DB instance deployed on ora3.host.com can have vol1 and vol2 for its data and logs, respectively. Those volumes together constitute the workload for that specific instance of the Oracle DB instance.
How does BlueXP ransomware protection prioritize workload data?
Data priority for the Preview version is determined by the Snapshot copies made and backups that are scheduled.
The workload priority is determined by the following Snapshot frequencies:
Critical: Snapshot copies taken less than 1 per hour (highly aggressive protection schedule)
Important: Snapshot copies taken less than 1 per day but greater than 1 per hour
Standard: Snapshot copies taken more than 1 per day
New volume added, but doesn't appear yet
If you added a new volume to your environment, initiate discovery again and apply protection policies to protect that new volume.
The Dashboard doesn't show all my workloads. What might be wrong?
Currently, only NFS volumes are supported. iSCSI volumes, CIFS volumes and other non-supported configurations are filtered out and do not appear on the Dashboard.
Protection policies
Do BlueXP ransomware policies co-exist with the other kinds of workload policies?
At this time, BlueXP backup and recovery (Cloud Backup) supports one backup policy per volume. So, BlueXP backup and recovery and BlueXP ransomware protection share backup policies.
Snapshot copies are not limited and can be added separately from each service.
