Cloud Volumes ONTAP release notes
What's new in Cloud Volumes ONTAP 9.18.1
You can now deploy and upgrade to Cloud Volumes ONTAP 9.18.1. You can see the base version of this release and the latest patch versions available for deployment and upgrade in the Console.
To know about the Cloud Volumes ONTAP features that are introduced in the latest versions of the NetApp Console, see what's new in Cloud Volumes ONTAP.
9.18.1 P8 (30 October 2026)
The Cloud Volumes ONTAP 9.18.1 P8 patch is now available for deployment and upgrade in AWS, Azure, and Google Cloud. The Console will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P8 patch (NetApp Support Site login required).
9.18.1 P3 (22 July 2026)
The Cloud Volumes ONTAP 9.18.1 P3 patch is now available for deployment and upgrade in AWS, Azure, and Google Cloud. The Console will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P3 patch (NetApp Support Site login required).
9.18.1 P2 (30 April 2026)
The Cloud Volumes ONTAP 9.18.1 P2 patch is now available for deployment and upgrade in AWS, Azure, and Google Cloud. The Console will prompt you to upgrade your existing systems to this patch release.
Note For AWS, Cloud Volumes ONTAP 9.18.1 P2 is the standard version for deployment and upgrade. Any lower version or patch of 9.18.1 is not supported.
View the list of bugs fixed in the P2 patch (NetApp Support Site login required).
9.18.1 P1 (31 March 2026)
The Cloud Volumes ONTAP 9.18.1 P1 patch is now available for deployment and upgrade in Azure and Google Cloud. The Console will prompt you to upgrade your existing systems to this patch release.
Note This version is not available for deployment and upgrade in AWS.
View the list of bugs fixed in the P1 patch (NetApp Support Site login required).
9.18.1 GA (10 February 2026)
The Cloud Volumes ONTAP 9.18.1 General Availability release is now available for deployment and upgrade in Microsoft Azure and Google Cloud.
Note This version is not available for deployment and upgrade in Amazon Web Services (AWS).
Upgrade notes
Read through these notes to learn more about upgrading to this release.
How to upgrade
Upgrades of Cloud Volumes ONTAP must be completed from the Console. You should not upgrade Cloud Volumes ONTAP by using System Manager or the CLI. Doing so can impact system stability.
Supported upgrade path
You can upgrade to Cloud Volumes ONTAP 9.18.1 from the 9.17.1 P1 and later patches in AWS, Azure, and Google Cloud. The Console will prompt you to upgrade eligible Cloud Volumes ONTAP systems to this release.
Downtime
  • The upgrade of a single-node system takes the system offline for up to 25 minutes, during which I/O is interrupted.
  • Upgrading an HA pair is non-disruptive and I/O is uninterrupted. During this non-disruptive upgrade process, each node is upgraded in tandem to continue serving I/O to clients.
