Cloud Volumes ONTAP
What's new in Cloud Volumes ONTAP 9.15.1
Contributors netapp-manini netapp-sumathi
Cloud Volumes ONTAP 9.15.1 includes new enhancements.
Additional features and enhancements are also introduced in the latest version of the NetApp Console. For more information, see what's new in Cloud Volumes ONTAP managed in the Console.
9.15.1 P16 (22 December 2025)
The 9.15.1 P16 patch is now available for Cloud Volumes ONTAP for all cloud providers. The Console will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P16 patch (NetApp Support Site login required).
9.15.1 P15 (24 October 2025)
The 9.15.1 P15 patch is now available for Cloud Volumes ONTAP for all cloud providers. The Console will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P15 patch (NetApp Support Site login required).
9.15.1 P14 (09 October 2025)
The 9.15.1 P14 patch is now available for Cloud Volumes ONTAP for all cloud providers. The Console will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P14 patch (NetApp Support Site login required).
9.15.1 P13 (09 October 2025)
The 9.15.1 P13 patch is now available for Cloud Volumes ONTAP for all cloud providers. The Console will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P13 patch (NetApp Support Site login required).
9.15.1 P12 (22 August 2025)
The 9.15.1 P12 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P12 patch (NetApp Support Site login required).
9.15.1 P11 (04 July 2025)
The 9.15.1 P11 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P11 patch (NetApp Support Site login required).
9.15.1 P10 (29 May 2025)
The 9.15.1 P10 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P10 patch (NetApp Support Site login required).
9.15.1 P8 (17 April 2025)
The 9.15.1 P8 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P8 patch (NetApp Support Site login required).
9.15.1 P7 (10 March 2025)
The 9.15.1 P7 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P7 patch (NetApp Support Site login required).
9.15.1 P6 (20 January 2025)
The 9.15.1 P6 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P6 patch (NetApp Support Site login required).
9.15.1 P5 (20 January 2025)
The 9.15.1 P5 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P5 patch (NetApp Support Site login required).
9.15.1 P4 (25 November 2024)
The 9.15.1 P4 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P4 patch (NetApp Support Site login required).
9.15.1 P3 (29 October 2024)
The 9.15.1 P3 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P3 patch (NetApp Support Site login required).
9.15.1 P2 (14 October 2024)
The 9.15.1 P2 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P2 patch (NetApp Support Site login required).
9.15.1 P1 (03 September 2024)
The 9.15.1 P1 patch is now available for Cloud Volumes ONTAP for all cloud providers. BlueXP will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P1 patch (NetApp Support Site login required).
9.15.1 GA (22 August 2024)
The Cloud Volumes ONTAP 9.15.1 GA is now available in AWS, Azure, and Google Cloud. The GA version is available for deployment and upgrade.
This release includes the following features and enhancements for Azure. Read on to learn more about the specific configurations supporting these new features.
Support for Premium SSD v2 Managed Disks in Azure
Premium SSD v2 Managed Disks are now supported in Cloud Volumes ONTAP systems on Azure. These premium disks provide higher performance with lower latency at a lower cost for both single node and high-availability (HA) pairs, as compared to Premium SSD Managed Disks. Like other managed disks, the maximum disk size is 32 TiB. The performance (capacity, throughput, and IOPS) of a Premium SSD v2 Managed Disks can be configured, allowing workloads to be cost effective, while meeting shifting performance needs.
Deploy HA pairs in single availability zones in Azure
Beginning with Cloud Volumes ONTAP 9.15.1, you can deploy virtual machine (VM) instances in HA mode in single availability zones (AZs) in Azure. Unlike the previous non-zonal deployments, Cloud Volumes ONTAP 9.15.1 uses Microsoft Virtual Machines Scale Sets in Flexible orchestration mode to deploy all resources, including separate fault domains within the same AZ, guaranteeing optimal availability. This deployment mode, by default, uses Premium SSD v2 Managed Disks when the following conditions are met:
If any of these criteria is not fulfilled, the previous non-zonal deployment mode for locally-redundant storage (LRS) becomes effective.
Support for Virtual Machines Scale Sets to unify all Azure HA types
Cloud Volumes ONTAP 9.15.1 leverages Virtual Machines Scale Sets in Flexible orchestration mode on Azure for deploying virtual machine (VM) instances in single availability zones for high-availability (HA) pairs. It covers all flavors of the HA mode, page blob, LRS, zone-redundant storage (ZRS) or multi-zonal, and LRS zonal (single AZ).
Support for FlexCache write-back
Beginning with Cloud Volumes ONTAP 9.15.1, FlexCache write-back is supported as an alternate mode of operation for writing at a cache.
For more information about this feature, refer to the ONTAP documentation FlexCache write-back overview.
For information about how BlueXP manages FlexCache volumes, refer to the BlueXP volume caching documents.
Upgrade notes
Read through these notes to learn more about upgrading to this release.
How to upgrade
Upgrades of Cloud Volumes ONTAP must be completed from BlueXP. You should not upgrade Cloud Volumes ONTAP by using System Manager or the CLI. Doing so can impact system stability.
Supported upgrade path
You can upgrade to Cloud Volumes ONTAP 9.15.1 from 9.15.0 and 9.14.1 releases. BlueXP will prompt you to upgrade eligible Cloud Volumes ONTAP systems to this release.
Downtime
  • The upgrade of a single node system takes the system offline for up to 25 minutes, during which I/O is interrupted.
  • Upgrading an HA pair is nondisruptive and I/O is uninterrupted. During this nondisruptive upgrade process, each node is upgraded in tandem to continue serving I/O to clients.
c4, m4, and r4 instances no longer supported
In AWS, the c4, m4, and r4 EC2 instance types are no longer supported with Cloud Volumes ONTAP. If you have an existing system that's running on a c4, m4, or r4 instance type, you must change to an instance type in the c5, m5, or r5 instance family. You can't upgrade to this release until you change the instance type.
Refer to NetApp Support to learn more about the end of availability and support for these instance types.
