NetApp Ransomware Resilience
Monitor workload health in NetApp Ransomware Resilience
Contributors netapp-ahibbard
Use the NetApp Ransomware Resilience dashboard to quickly see workload protection health, identify workloads that are at risk or in recovery, and gauge how much storage is protected.
Use the dashboard to review protection recommendations, change settings, and download reports.
Required Console role
To perform this task, you need the Super admin, Ransomware Resilience admin, or Ransomware Resilience viewer role. Learn about Ransomware Resilience roles for NetApp Console.
Review workload health using the dashboard
Steps
  1. After the Console discovers your workloads, the Ransomware Resilience dashboard displays workload data protection health.
    Dashboard page
  2. From the dashboard, you can do the following actions in each pane:
    • Workload data protection: Select View all to see all workloads that are at risk or protected on the Protection page. Without either encryption detection or user activity detection, the workload is considered at risk. Refer to Protect workloads.
      Tip Select the "i" icon to see tips on this data. To increase the workload limit, select Increase workload limit inside this i note. Selecting this takes you to the Console Support page where you can create a case ticket.
    • Alerts and workload data recovery: Select View all to see active incidents that have impacted your workload, are ready for recovery after incidents are neutralized, or are in recovery. Refer to Respond to a detected alert.
      • An incident is categorized in one of the following states:
        • New
        • Dismissed
        • Dismissing
        • Resolved
      • An alert can have one of the following statuses:
        • New
        • Inactive
      • A workload can have one of the following restore statuses:
        • Restore needed
        • In progress
        • Restored
        • Failed
    • Recommended actions: To increase protection, review each recommendation and select Review and fix.
      Ransomware Resilience displays new recommendations since your last visit to the dashboard with the "New" tag for 24 hours. Actions appear in priority order, with the most important at the top. Review, act on, or dismiss each recommendation.
      The total number of actions does not include actions you dismissed.
    • Workload data: Monitor changes in protection coverage over the last 7 days.
    • Workload backups: Monitor changes in workload backups created by Ransomware Resilience that failed or completed successfully in the last 7 days.
Review protection recommendations on the dashboard
Ransomware Resilience assesses the protection on your workloads and recommends actions to improve that protection.
You can review a recommendation and act on it, which changes the recommendation status to Complete. Or, if you want to act on it later, you can dismiss it. Dismissing an action moves the recommendation to a list of dismissed actions, which you can review later.
Here is a sampling of the recommendations that Ransomware Resilience offers.
Recommendation Description How to resolve
Add a ransomware protection policy.
The workload is currently not protected.
Assign a policy to the workload.
Refer to Protect workloads against ransomware attacks.
Connect to SIEM for threat reporting.
Send data to a security and event management system (SIEM) for threat analysis and detection.
Enter SIEM/XDR server details to enable threat detection.
Refer to Connect to a SIEM.
Improve security posture for system
NetApp Digital Advisor has identified at least one high or critical security risk.
Review all security risks in NetApp Digital Advisor.
Refer to Digital Advisor documentation.
Make a policy stronger.
Some workloads might not have enough protection. Strengthen protection on workloads with a policy.
Increase retention, add backups, enforce immutable backups, block suspicious file extensions, enable detection on secondary storage and more.
Prepare <backup provider> as a backup destination to back up your workload data.
The workload does not currently have any backup destinations.
Add backup destinations to this workload to protect it.
Refer to Add a backup destination.
Protect critical or highly important workloads against ransomware.
The Protect page displays critical or highly important (based on the Priority level assigned) workloads that are not protected.
Assign a policy to these workloads.
Protect critical or highly important file share workloads against ransomware.
The Protection page displays critical or highly important workloads of the type File Share or Datastore that are not protected.
Assign a policy to each of the workloads.
Review new alerts.
New alerts exist.
Review the new alerts.
Refer to Respond to a detected ransomware alert.
Steps
  1. From the Recommended actions pane in Ransomware Resilience, select a recommendation then Review and fix.
  2. To dismiss the action until later, select Dismiss.
    The recommendation clears from the To Do list and appears on the Dismissed list.
    Tip You can later change a dismissed item to a To Do item. When you mark an item as completed or you change a dismissed item to a To Do action, the Total actions count increases by 1.
  3. To review information on how to act on the recommendations, select the information icon.
Export protection data to CSV files
You can export data and download CSV files that show details of protection, alerts, and recovery.
You can download CSV files from any of the main menu options:
  • Protection: Contains the status and details of all workloads, including the total number of workloads that Ransomware Resilience marks as protected or at risk.
  • Alerts: Includes the status and details of all alerts, including the total number of alerts and automated snapshots.
  • Recovery: Includes the status and details of all workloads that need to be restored, including the total number of workloads that Ransomware Resilience marks as "Restore needed", "In progress," "Restore failed," and "Successfully restored."
Downloading a CSV file from a page includes only the data from that page.
The CSV files include data for all workloads on all Console systems.
Steps
  1. From the Ransomware Resilience dashboard, select the Refresh Refresh option option in the upper right to refresh the data that will appear in the files.
  2. Do one of the following:
    • From the page, select the Download Image of the download option icon option.
    • From the Ransomware Resilience menu, select Reports.
  3. If you selected the Reports option, select one of the preconfigured named files then select Download (CSV) or Download (JSON).
Access technical documentation
You can access Ransomware Resilience technical documentation from docs.netapp.com or from inside Ransomware Resilience.
Steps
  1. From the Ransomware Resilience dashboard, select the vertical Actions Vertical Actions option option.
  2. Select one of these options:
    • What's new to view information about the features in the current or previous releases in the Release Notes.
    • Documentation to view the Ransomware Resilience documentation Home page and this documentation.
