Enable a premium feature
A premium feature is an extra option that requires a key to enable.
You have obtained a feature key. If necessary, contact technical support for a key.
You have loaded the key file on the management client (the system with a browser for accessing System Manager).
This task describes how to use System Manager to enable a premium feature.
If you want to disable a premium feature, you must use the Disable Storage Array Feature command ( |
Select
Under Add-ons, select Enable Premium Feature.
The Enable a Premium Feature dialog box opens.
Click Browse, and then select the key file.
The file name is displayed in the dialog box.
Click Enable.
