Export key management server certificates
You can save a certificate for a key management server to your local machine.
Before you begin
  • You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
  • Certificates must be previously imported.
Steps
  1. Select Settings  Certificates.
  2. Select the Key Management tab.
  3. From the table, select the certificate you want to export, and then click Export.
    A Save dialog box opens.
  4. Enter a filename and click Save.
