Element Software
Configure the cluster to listen for NTP broadcasts
Contributors netapp-pcarriga
By using the broadcast mode, you can instruct each node in a cluster to listen on the network for Network Time Protocol (NTP) broadcast messages from a particular server.
The NTP is used to synchronize clocks over a network. Connection to an internal or external NTP server should be part of the initial cluster setup.
What you'll need
  • You must have cluster administrator privileges to configure this setting.
  • You must configure an NTP server on your network as a broadcast server.
Steps
  1. Click Cluster > Settings.
  2. Enter the NTP server or servers that are using broadcast mode into the server list.
  3. Under Network Time Protocol Settings, select Yes to use a broadcast client.
  4. To set the broadcast client, in the Server field, enter the NTP server you configured in broadcast mode.
  5. Click Save Changes.
