Keystone
2.0
Data Infrastructure Insights add-on for Keystone STaaS
Contributors netapp-shwetav
NetApp Data Infrastructure Insights (DII, formerly known as Cloud Insights) is an add-on service for Keystone STaaS. The integration of this service with Keystone STaaS enhances the monitoring, troubleshooting, and optimization capabilities of Keystone-provided storage resources across public clouds and private data centers.
To learn more about Data Infrastructure Insights, refer to Data Infrastructure Insights documentation.
About DII for Keystone subscriptions
DII is available for both new and existing subscriptions. It can be integrated into a Keystone subscription as an add-on for the committed capacity.
When DII is integrated into a Keystone subscription, it will have a corresponding performance service level for each base performance service level in the subscription. For example, Extreme maps to DII Extreme, Premium maps to DII Premium, and Performance maps to DII Performance. These mappings ensure that the DII performance service level aligns with the base performance service level of your Keystone subscription.
Deployment of DII for Keystone
Customers can integrate DII for Keystone in two ways: either as part of an existing instance that monitors other non-Keystone environments, or as part of a new instance. It is the customer's responsibility to set up DII. If help is needed for setting up DII in a complex environment, the account team can engage NetApp Professional Services.
To set up DII, refer to Data Infrastructure Insights onboarding.
Note the following:
  • If the customer is starting a new DII instance, it is recommended to begin with a DII free trial. To learn about this feature and the required startup checklist, refer to Feature Tutorials.
  • For each site, an Acquisition Unit is required. To install an Acquisition Unit, refer to Install an Acquisition Unit. If the customer already has a DII instance and Acquisition Unit set up, they can proceed with configuring the data collector.
  • For each storage hardware deployed, the customer must configure a data collector on the Acquisition Unit. To configure data collectors, refer to Configure Data Collectors. The required data collectors for Keystone storage, based on the underlying hardware, are as follows:
    Storage hardware Data collector
    ONTAP Systems
    NetApp ONTAP Data Management Software
    StorageGRID
    NetApp StorageGRID
    Cloud Volumes ONTAP
    NetApp Cloud Volumes ONTAP
    Once configured, the DII instance will begin monitoring the NetApp storage resources deployed as part of Keystone.
Note While DII offers extensive monitoring capabilities for the deployed hardware, it does not provide insights into your Keystone subscription, such as subscription usage or details on performance service levels. For subscription insights, see Keystone dashboard and reporting.
View DII consumption
You can view the consumption for your DII add-on services through the NetApp Console or Digital Advisor. The consumption data for DII performance service levels (such as DII Extreme, DII Premium, and DII Performance) appears alongside your base performance service levels in the current consumption and consumption trend views.
The following example shows DII performance service level in the Current consumption tab in the Console:
Screenshot of current consumption tab displaying DII service levels
The following example shows DII performance service levels in the Keystone Subscriptions widget in Digital Advisor:
Screenshot of Keystone Subscriptions widget displaying DII service levels
For more information about viewing consumption, see:
Billing and metering
The following outlines the billing and metering details of the DII add-on service:
  • This service is measured in the same way as your main subscription. For example, if your main subscription includes 100 TiB of Extreme service and 100 TiB of Premium service, both measured on a logical usage basis, the add-on services, DII Extreme 100 TiB and DII Premium 100 TiB, are also measured on a logical usage basis. If your main subscription is measured on a provisioned basis, the add-on service is measured the same way for the same capacity. The add-on service will follow the same measurement method as your main subscription.
  • This service is metered and invoiced along with your Keystone subscription on the same invoice. If you configure DII for Keystone before activating your Keystone subscription, billing still begins from the Keystone subscription activation date, or the modification date for existing subscriptions.
  • This service is metered and invoiced based on both committed capacity and burst usage for DII performance service levels, in addition to the standard Keystone invoice. The metering of this add-on service follows the same methodology as the underlying Keystone subscription performance service level, which could be logical, provisioned, or physical.
  • This service ends with the Keystone subscription to which it is linked. At renewal, you can choose whether to renew the add-on service. If you don't renew the Keystone subscription, the monitored hardware is decommissioned, and the add-on service automatically terminates.
Support and user access
Approved NetApp Support team members can access the customer's DII instance if the customer enables the Allow NetApp Access to your Data Infrastructure Insights Environment option. To do so, go to Help > Support, and enable the option.
Screenshot demonstrating how the customer can enable the option
Customers can provide access to internal or external users from the User Management screen using the user button option.
Screenshot showing the option of adding user
