Deployment overview
Before you get started, you might want to better understand your options for deploying Cloud Manager and Cloud Volumes ONTAP.
Cloud Manager installation
Cloud Manager software is required to deploy and manage Cloud Volumes ONTAP. You can deploy Cloud Manager in any of the following locations:
Amazon Web Services (AWS)
Microsoft Azure
Google Cloud Platform
Cloud Manager must be in Google Cloud Platform when deploying Cloud Volumes ONTAP in GCP.
IBM Cloud
In your own network
How you deploy Cloud Manager depends on which location you choose:
| Location for Cloud Manager | How to deploy Cloud Manager | ||
AWS |
AWS C2S |
Deploy Cloud Manager from the AWS Intelligence Community Marketplace |
Azure generally available region |
Azure Government |
Deploy Cloud Manager from the Azure US Government Marketplace |
Azure Germany |
Google Cloud Platform |
IBM Cloud |
On-premises network |
Cloud Manager setup
You might want to perform additional setup after you install Cloud Manager, such as adding additional cloud provider accounts, installing an HTTPS certificate, and more.
Cloud Volumes ONTAP deployment
After you get Cloud Manager up and running, you can start deploying Cloud Volumes ONTAP in your cloud provider.
Getting started in AWS, Getting started in Azure, and Getting started in GCP provide instructions for getting Cloud Volumes ONTAP up and running quickly. For additional help, refer to the following:
