REST API reference
Delete an external NTP server
Deletes an external NTP server to remove it from the configuration used by ONTAP.
HTTP method and endpoint
DELETE /cluster/ntp/servers/{server}
Introduced in
ONTAP 9.7
Usage notes
Deletes an external NTP server used by ONTAP.
  • cluster time-service ntp server delete
server
string
path
True
Server address or host name
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
