REST API reference
Delete an external NTP server
Removes an external NTP server that ONTAP uses. This operation is typically performed when the NTP server is no longer required or needs to be replaced.
HTTP method and endpoint
DELETE /cluster/ntp/servers/{server}
Introduced in
ONTAP 9.7
Usage notes
Deletes an external NTP server used by ONTAP.
  • cluster time-service ntp server delete
server
string
path
True
Server address or host name
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
