Delete an external NTP server
Removes an external NTP server from the configuration to stop its use by ONTAP for time synchronization. This action is typically performed when updating or decommissioning time server resources.
HTTP method and endpoint
DELETE /cluster/ntp/servers/{server}
Introduced in
ONTAP 9.7
Usage notes
Deletes an external NTP server used by ONTAP.
Related ONTAP commands
cluster time-service ntp server delete
Learn more
server |
string |
path |
True |
Server address or host name |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
