Delete an external NTP server
Deletes an external NTP server that ONTAP uses for time synchronization. Use this to manage and remove NTP server configurations no longer needed in your environment.
HTTP method and endpoint
DELETE /cluster/ntp/servers/{server}
Introduced in
ONTAP 9.7
Usage notes
Deletes an external NTP server used by ONTAP.
Related ONTAP commands
cluster time-service ntp server delete
Learn more
server |
string |
path |
True |
Server address or host name |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
