Delete an FC WWPN alias
Deletes an FC WWPN alias to manage or update your Fibre Channel network configuration effectively.
HTTP method and endpoint
DELETE /network/fc/wwpn-aliases/{svm.uuid}/{alias}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver fcp wwpn-alias remove
Learn more
svm.uuid |
string |
path |
True |
alias |
string |
path |
True |
The name of FC WWPN alias. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1260882 |
An SVM with the specified UUID does not exist. |
5374046 |
The alias could not be found. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
