REST API reference
Delete an FC WWPN alias
Removes an FC WWPN alias when it is no longer needed, streamlining your network's configuration and freeing up resources.
HTTP method and endpoint
DELETE /network/fc/wwpn-aliases/{svm.uuid}/{alias}
Introduced in
ONTAP 9.6
Usage notes
Deletes an FC WWPN alias.
  • vserver fcp wwpn-alias remove
svm.uuid
string
path
True
alias
string
path
True
The name of FC WWPN alias.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The specified SVM does not exist or cannot be accessed by this user.
5374046
The alias could not be found.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
