      Delete an FC WWPN alias
DELETE /network/fc/wwpn-aliases/{svm.uuid}/{alias}
Introduced In: 9.6
Deletes an FC WWPN alias.
Related ONTAP commands
vserver fcp wwpn-alias remove
Learn more
svm.uuid  |
string  |
path  |
True  |
The unique identifier of the SVM.  |
alias  |
string  |
path  |
True  |
The name of FC WWPN alias.  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1260882  |
An SVM with the specified UUID does not exist.  |
5374046  |
The alias could not be found.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
